Author Topic: Can someone tell me what these wires on the fusebox do?  (Read 13745 times)
Re: Can someone tell me what these wires on the fusebox do?
« Reply #15 on: November 15, 2009, 12:38:52 am »
i had to use a bluepoint first time using butane. now thats all i try to use
Offline aussie
« Reply #16 on: November 20, 2009, 09:04:22 am »
hows it going have you started it yet????????
Offline team39763
« Reply #17 on: November 20, 2009, 11:45:58 am »
Yep, I got it running.  A buddy came by and gave me an old kill switch that he had from his tractor and it worked perfect.  I used all the info I got from you guys and got the wires/connections correct.  Now I'm just trying to pump myself up to go out there and remove the wedges I installed to change the pinion angle.  I'll start a thread on that in a bit because I'm kinda lost.  Other than that, I just have to wire up my turn signals/headlights and find somebody to weld on my home-made front rollpan. Thanks for all the help guys.
