Author Topic: Rebuilding my 87  (Read 156001 times)
Offline 87OldYeller
Re: Rebuilding my 87
« Reply #45 on: January 17, 2010, 09:04:51 pm »
if you could get exhaust manifold bolts, i have seen people use intake bolts you can if you want them make a bracket to do that with that will fit the curve, I assume you still have the fenders and radiator core support in? and just a tip take a plastic bag or something and wrap up around the transmission rear seal, you will lose fluid when lifting it out.
Offline fptransport
« Reply #46 on: January 17, 2010, 09:27:12 pm »
thanks that engine leveler, have for chain  ends so I was thinking on grabbing it from two bolts on the back from the tranny housing to engine, and two in from from one or two pulleys?  ???
Offline 87OldYeller
« Reply #47 on: January 17, 2010, 09:50:19 pm »
umm might could give it a try. sounds like it might work.
Offline fptransport
« Reply #48 on: January 17, 2010, 10:12:54 pm »
with my luck the bolt will break and damage my rad. support or a fender.... and that will be my  excuse to swap to the 91 front end.. ;D
« Reply #49 on: January 17, 2010, 11:05:35 pm »
It may be tight but you could pull the accessories off and put bolts in all the heads.
OR pull the intake and put longer bolts in all the bolt holes int the 4 corners.
Offline fptransport
« Reply #50 on: January 18, 2010, 06:45:57 pm »
thanks guys,, I over came my fears and bolt it to some of the acc bolts and one intake bolt, came right out... only thing is I cut the main harness which is like 10 -12 wires and now I am gonna have to figure out where they went...
Offline fptransport
« Reply #51 on: January 19, 2010, 11:46:41 am »
have one question... are you going to re use the radiator that you had, and if so, how do you hook up the tranny lines to it,, can you re fit it to the old style threads?
sorry for the questions but I am new to this
Offline 87OldYeller
« Reply #52 on: January 19, 2010, 12:04:36 pm »
Yes i am going to use the old radiator. actually i am having custom bradded stainless steel lines built for almost everything
Offline 2502
« Reply #53 on: January 19, 2010, 12:09:58 pm »
subscribed. i wanna see the results i'm interested. lol
Offline SUX2BU99
« Reply #54 on: January 19, 2010, 02:12:35 pm »
Great progress. I love the tear-down pics of the truck. Lets me know what's lurking behind my fenders! What kind of paint did you use on the firewall and inner fenders? Rattle can? Pretty glossy.
Offline 87OldYeller
« Reply #55 on: January 19, 2010, 06:54:38 pm »
yea the old rattle can. you can make that stuff look great with prep work good sanding and a good coat of primer and put on a few coats or high temp engine paint (Gloss black). But i used a sprayer on the can one of the big ones trigger action ones and it controls the spray very nicely.
Offline fptransport
« Reply #56 on: January 19, 2010, 07:00:20 pm »
thanks oldyeller,  I asked, because it looks like you can take off the fittings at the 4l60e for the cooler lines and put the fittings off the 700r4 in to use the old style line, but i was just wonder ::)
nice work, you've been doing
Offline 87OldYeller
« Reply #57 on: January 19, 2010, 08:00:54 pm »
thanks a a lot. hey let me know how that works out with the 700R4 Lines. Never looked into it but i am going to run the factore 4l60E transmission cooler. So i have to figure all that out. I think i might try to bolt in the engine and transmission tonight. it is late and dark but i have nothing else to do.
Offline fptransport
« Reply #58 on: January 19, 2010, 08:45:26 pm »
I wound be able to test to see if it works I am having to work for the next 3 or 4 days  >:(  ..
hey this is the first old truck I have/mod, but when the 5.3 where is the brake booster vaccum line attached to?
by the way,, I didnt have my tranny till today,,, and I got a 2008 4L60E out of a tx state trooper tahoe with 15k miles for 400...plus and extra MAF just incase  ;D
Offline 87OldYeller
« Reply #59 on: January 19, 2010, 09:32:34 pm »
WOW great deal. yea i found some cool parts for this motor, like a MAFS that bolts directly to the throttle body with a polished square cover that says LS1 I got to have it. :)
