Author Topic: rod door panels  (Read 13738 times)
Offline Flamingbig10
Re: rod door panels
« Reply #15 on: December 22, 2009, 11:49:01 am »
Woo Hoo! I sent an email to Rod Doors directly and was able to get a set he had in stock. That made my Christmas! Anyone know what triming had to be done to fine tune these to fit?
the best way is to fit them first, and see what needs trimming but you will have to cut out for power switches or Manuel window crank and the door lock rod
Re: rod door panels
« Reply #16 on: December 22, 2009, 11:52:14 am »
There is a bump/dimple where the window crank is, just find it and drill it out.
Offline CeeTen
Re: rod door panels
« Reply #17 on: December 23, 2009, 10:22:50 pm »
Sweet! Will order a pair in the next day or so!
Offline jim84
Re: rod door panels
« Reply #18 on: December 24, 2009, 11:42:08 am »
Quote
Yea, I am test fitting them now, I have power locks and shaved doors. It looks like the side closest to the lock rod fits ok, but the side near the wind wing needs quite a bit of force to make it snug up to the window. Did you guys only use the Durloc to hold it or were there screws under 2nd piece that goes over the top.
Don't mind the paint on the glass. I have to swap the glass with my other doors.
« Last Edit: December 28, 2009, 10:50:31 am by Captkaos »
