Author Topic: Crusty 4-core radiator (rebuild or replace)  (Read 19985 times)
Offline Whitfield
  • Building a V-3500 Crew Cab 4wd
Re: Crusty 4-core radiator (rebuild or replace)
« Reply #15 on: January 02, 2010, 12:54:20 pm »
http://www.completeradiators.com/shop/results.asp?pid=18&cboyear=1988&cbomake=GMC&cbomodel=V3500&cbosubmodel=%28None%29&cboengine=734393780|V8+6.2+Liter+379+CID++Diesel&pt=Complete+Radiators
OE style 6.2l Diesel 3 row @ $325 & free shipping  :)
Core Size   34 x 19 1/4 x 2 5/8   Rows   3
Tank Inlet   3 1/2 x 20 7/8   Tank Outlet   3 1/2 x 20 7/8
Inlet Conn   1 3/4 Top Left   Outlet Conn   1 3/4 Bottom Right
Trans Oil Cooler   8 1/2   Engine Oil Cooler   8 1/2
Construction   Copper Brass   Mounting   Channel
Heater Return Line on RH Tank; TOC adapters included in kit
Offline joesgarage71
  • Wrench
« Reply #16 on: January 04, 2010, 08:20:32 am »
Offline Whitfield
« Reply #17 on: January 06, 2010, 08:52:45 am »
My local Radiator shop just called:  Still searching and recomended a 1995 454 radiator like this one pictured below.  Plastic tanks / updated efficient aluminium core / tubes.  They claim that this one attaches thru stock type saddle mounts and will be a direct interchange for my 1988.  I thoguht they switched away from saddle style mounts by 95.   :-\
w/EOC, and 1-1/2 thick, for 2" version call us
short neck is around 3" raised, aluminum core style
CORE SIZE: 34 x 19 x 1-1/2
http://www.radiatorexpress.com/product.asp?part=1995+CHEVROLET+K3500++%2D+7%2E4+liter+V8+RADIATOR+Brand+Replacement+%2834%22x19%22%29+w%2F+Short+Neck+3%22+&part_id=39194&aaia_id=1053379
Offline Whitfield
« Reply #18 on: January 22, 2010, 12:42:05 am »
Ordered an original (48 pound / brass & copper) Diesel 3-core radiator.
First one Fed-ex dropped and crushed the fill neck.
Second one looked like the core had been kicked by a class room of kinder gardeners.
Company refunded my $$$ and I bought a 1995 aluminium 2-core 454 truck radiator locally for $240
SO far everything says direct fit comparing the two.  Once the rain stops and we get some good weather I'll update more.
