Author Topic: Clunking noise???  (Read 16172 times)
Offline Grover 1
Re: Clunking noise???
« Reply #15 on: December 17, 2009, 09:58:09 pm »
Have you checked the shocks?  I had a clunk like that and it was a bad shock bushing, sounded like it was coming from the floorboard.
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
And here I sit so patiently
You have to pay to get out of
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #16 on: December 17, 2009, 10:01:01 pm »
Quote
when the truck is in park on a slope and not running i can rock the truck and it makes that noise too now i noticed,
do that and chaulk the tires well.  Get up under the truck while someone rocks the trucks.
also, jack up under the frame taking weight off the wheel, one front side at a time, and just rock the wheel and push up on control arm and move it as much as you can til you see what has play in it.
Offline hotrodpc
« Reply #17 on: December 17, 2009, 10:16:15 pm »
I'll agree with Sarge here. It is very hard to check suspension when its on the ground, and if you are by yourself. Truck sitting motionless with the weight on the parts, its hard to find a loose suspension parts. You can also jack the frame up in the front to where the tires about 2 inches off the ground, get you about a 4 ft 2x4 and put it under the tires and use the 2x4 as a pry bar and lift the tire and have someone watching your bushings for excessive movement.
80 GMC C15 SierraGrande Long Bed  Was Diesel Now Olds 350 Gas/T350
86 Chevv C20 Silverado Long Bed 454/T400
81 GMC C15 Sierra Grande Long Bed 305/T350 Non LU.
84 Chev C20 Scottsdale Longbed To Be Olds 455/T400
85 Chev K10 Silverado Longbed 350/700r4
Offline 1981 ss chevy
« Reply #18 on: December 18, 2009, 06:21:28 pm »
thanks you guys it was a bad bushing after all your tips are greatly appreciated
Offline hotrodpc
« Reply #19 on: December 18, 2009, 11:00:28 pm »
Awesome !!! You're 50% done just knowing what it is. Have you started the install yet? Which bushing is it?
« Reply #20 on: December 25, 2009, 01:45:17 pm »
it was the driver side front shock the bushing that is actually inside the shock itself if you kno what im talking about its hard to explain lol well i just put new shocks up front and now its all smooth noiseless sailing
Offline hotrodpc
« Reply #21 on: December 25, 2009, 07:27:57 pm »
I know exactly what you are talking about. See, those noises do play tricks. You thought it was under the cab. I tell people stuff like that all the time. No, its not that, its coming from here or there. Just like roof leaks. Its not leaking where you see the puddling in the ceiling like many think.
« Reply #22 on: December 26, 2009, 09:58:57 am »
exactly right
