Author Topic: Measuring Pushrods  (Read 17642 times)
Offline malibu795
Re: Measuring Pushrods
« Reply #15 on: January 02, 2010, 10:06:30 pm »
what camshaft did you get? also timing chain is almost require swapout as well with new cam
BTW rocker on SBC do not have torque specs.!!
what did you set timeing at?  at idle or max timing?
adam wildman
75 K25 383/400
Offline 4x4Cowgirl
  • Country girls like it dirty
    • Facebook
« Reply #16 on: January 02, 2010, 10:10:17 pm »
I got a cam from Engine Tech with an overall duration of .443 on intake and .465 on exhaust
A buddy of mine thats a chevy nut gave it to me today for free  ;D
So timing chain too? Man lol it keeps addin up!
ok rockers on sbc... no torque specs LOL  :D
Offline malibu795
« Reply #17 on: January 02, 2010, 10:11:54 pm »
.443/.465 is lift not duration  ;)
duration would be some were around 200-220* @ .050" lift
adam wildman
75 K25 383/400
Offline 4x4Cowgirl
    • Facebook
« Reply #18 on: January 02, 2010, 10:17:13 pm »
lol i am still learning the engine talk. I only know 4 wheel drives so far hahah.
ok on the box it says .214-.224 at .050
does that sound right?
Offline malibu795
« Reply #19 on: January 02, 2010, 10:18:46 pm »
yep  :) thats duration the valves are open in realtion to crankshaft rotation ;)
adam wildman
75 K25 383/400
Offline 4x4Cowgirl
    • Facebook
« Reply #20 on: January 02, 2010, 10:20:20 pm »
ooooooooooo!!!!!! ok cool! i learned somethin new again!  :P
so with that size cam, do i need to like upgrade any other parts to coordinate with it?
Offline malibu795
« Reply #21 on: January 02, 2010, 10:29:58 pm »
unless you know what springs are in there... my first thought woudl be to up-grade the valve springs.. so you know whats in there..
stock lift was less then .400" on alot of these engines..
http://www.summitracing.com/parts/SUM-174001/  these will allow you to handle up to .490" lift
and yes this stuff adds up.
adam wildman
75 K25 383/400
Offline 4x4Cowgirl
    • Facebook
« Reply #22 on: January 02, 2010, 10:39:55 pm »
Shoot, I have no idea. I'll have to get my boyfriend to check it out when we pull the motor I guess. LoL. I was really only wantin to fix what was wrong with the motor such as the pushrods and the rear main seal this way I don't spend an arm and a leg.... But with this new cam, I don't know now.  ???
Offline malibu795
« Reply #23 on: January 02, 2010, 10:44:20 pm »
understood..
i woudl get the push rods and oil leak fixed.. save the cam swap for a later date.. give you time to get springs and other stuff linded up and your truck back up and runnning.
oil pan gasket can be swap in truck if its 4wd..  if its actually the main you can do it in the truck.. though it will be a $#@%.. doing it on your back..
adam wildman
75 K25 383/400
Offline 4x4Cowgirl
    • Facebook
« Reply #24 on: January 02, 2010, 10:48:56 pm »
Yeah I have done the oil pan gasket 3 times already. 1 with just a new gasket. Didn't work. Bought a new oil pan. Didn't work. Then used silicone and new gasket and loc tite on the bolts. Didn't solve the leak. So it has to be the rear main. Yeah, I don't think I want to do it since my trucks so high off the ground it would be a b*@#! to do. So we were just gonna take it out that way I can go ahead and repaint the block and heads and go thru the motor to see what all is there and if anything else is screwed up. But I really don't wanna have to screw with this motor again for a while after we put it back in, that's why I was contemplating goin ahead and doin it all at once but man it's addin up. Might need to get a loan out LMAO.
Offline malibu795
« Reply #25 on: January 02, 2010, 10:55:05 pm »
your looking at close to 600-700 in parts roughly...
bearings,
gaskets
timing chain,
valve spring set
piston rings
push rods
granted it can be done for less.. pendign what make the priority list and what doesnt.....dont for get to add 100-150 or so for broken/loss stuff, fluid and gernal misc stuff, new plugs/wire be a good idea pending condition of current set.
adam wildman
75 K25 383/400
Offline 4x4Cowgirl
    • Facebook
« Reply #26 on: January 02, 2010, 11:05:07 pm »
Yeah, so far I have replaced the oil pan, oil pan gasket, spark plugs, oil change, and that's about it. Set the timing where it lopes pretty decently. But shoot, All I wanna do is drive it again LOL. I got it in October, drove it for a few days and its been parked ever since. Pissed me off to see it just sittin there! So hopefully we can get this ball rollin before too long!  :)
