Author Topic: Axle shaft U Joint  (Read 25722 times)
Re: Axle shaft U Joint
« Reply #15 on: May 22, 2010, 06:53:48 pm »
no seal there but theres on on the back side of the hub, theres one  near the ring and pinion also
« Reply #16 on: May 24, 2010, 08:39:54 pm »
The back side of the hub, you talking about where the inner spindle bearing goes on? Its metal with a rubber seal and a coiled wire in it. I got that piece. I also replaced the rubber seal and metal plate that goes on the outer axle shaft. It meets up with the backside of the spindle.
I dont like the idea that there is nothing sealing the axle tube. Oh well I guess. Its odd that it looks like there should be something there, especially with the recessed lip that you can see in the first pic.
Offline malibu795
« Reply #17 on: May 30, 2010, 01:53:36 pm »
the seal is inside the diff housing right before the tube.
to change them you have to pull the diff apart.
adam wildman
75 K25 383/400
