Author Topic: The Citation needs Nicorette!  (Read 9683 times)
Offline jaredts
Re: The Citation needs Nicorette!
« Reply #15 on: January 25, 2010, 06:42:46 am »
Valve guides is a common part of the head rebuild.  No biggie there, but you might want to snoop around a little more before you yank the head off and send it to the machine shop.  You can buy a leakdown tester or just adapt and pump compressed air into the spark plug hole with the cylinder in question at TDC on compression stroke.  Then air will escape either through the exhaust valve, intake valve, rings, or head gasket.  Look up the instructions for a leakdown test for more detail.  If you want to try and fix this without pulling the motor, you need to verify the bottom end.  My guess is that you need more than just a head rebuild, but you never know.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #16 on: January 25, 2010, 07:36:38 am »
i would think that the same spark plug would get fouled periodically if you have a bad valve seat.  Is this not true?
Offline Layne
« Reply #17 on: January 25, 2010, 03:35:25 pm »
They've never fouled. Had them in there about 4 years now. They were always gray except now #1 is orangey
Offline Jim Rockford
  • Banned
« Reply #18 on: February 02, 2010, 10:31:41 am »
run some seafoam in the oil for about an hour before you change the oil.
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
