Author Topic: Junk or gold?  (Read 28605 times)
Re: Junk or gold?
« Reply #30 on: March 01, 2010, 01:21:38 am »
now don't quote me on this but i had a 3/4 ton frame well 2 of them both were the same size and they both were as thick as my 1/2 ton about 6" don't know if thats light duty or what but i saw a 1 ton that was like 8" or something. not sure about cab part tho never saw anthing that stood out
Offline Lucky73
Re: Junk or gold?
« Reply #31 on: March 05, 2010, 12:23:08 am »
I just came up on an 8'' lift and extended drive lines for 400$Gona be sweet.ill post pix in projects when I start to do it ;D
73 Chevy C10
73 GMC K20
93 Chevy S-10
Re: Junk or gold?
« Reply #32 on: March 05, 2010, 09:25:20 am »
That's a good deal just make sure u have the same size rear srpings or you will be cutting and pasting
Offline bobcooter
  • 1979 Scottsdale C-20
Re: Junk or gold?
« Reply #33 on: March 05, 2010, 11:12:42 am »
Did anyone notice the perfectly straight front bumper? That's worth a close to a couple of hundred right there!
Offline Lucky73
Re: Junk or gold?
« Reply #34 on: March 07, 2010, 03:54:23 pm »
same size leaf springs ???what do you mean
73 Chevy C10
73 GMC K20
93 Chevy S-10
Re: Junk or gold?
« Reply #35 on: March 08, 2010, 04:33:14 am »
the chevy trucks came with 52" or 56" rear springs they cant be swapped out with each other
Offline fitz
Re: Junk or gold?
« Reply #36 on: March 08, 2010, 06:16:03 pm »
All you have to do is move the rear spring hanger to switch from one to the other. Grind off the rivits, clean them up and reattach them using grade 8 hardware.
Offline Lucky73
Re: Junk or gold?
« Reply #37 on: March 08, 2010, 11:13:31 pm »
Realy thats good to know.thanks,but what trucks came with what size spring ???
73 Chevy C10
73 GMC K20
93 Chevy S-10
Re: Junk or gold?
« Reply #38 on: March 08, 2010, 11:38:03 pm »
you got to measure them to find out, thats why i said you might have to cut and paste. like Fitz explained it ain't nothing to do it
Offline Lucky73
Re: Junk or gold?
« Reply #39 on: March 09, 2010, 09:44:18 pm »
ok ill check it out.thanks again.
73 Chevy C10
73 GMC K20
93 Chevy S-10
