Author Topic: 85 1 ton Dually- Cummins Swap  (Read 178964 times)
Offline cubicdollars
Re: 85 1 ton Dually- Cummins Swap
« Reply #15 on: March 14, 2010, 08:41:37 am »
I figured I'd Ebay it and try to recoup some money :):)
« Reply #16 on: March 15, 2010, 07:31:29 pm »
This is what I am going to be pulling with my cummins conversion :)
« Reply #17 on: March 19, 2010, 08:07:06 am »
Alright I recieved my parts from Autoworld they were pretty expensive but to be able to use GM Parts it was worth it to me, My only concern is having to the the center section out, For as small as that pan is I am not sure I will have to cut anything it all depends how low the engine sits in compared to the BBC. Here is the list with Part numbers and prices
Motor Mount kit for GM 73-00/2wd                             GMMM                              $375.00
AC/Alt Bracket set for Harrison Pump                         No P/N                             $250.00
Dual Pulley for new Brackets                                    NO P/N                             $150.00
Belt 6V X 40                                                          K060400                            $21.00
Belt-Serp 6 Groove for A/C                                       K060705                            $35.00
Cover for oil sevise on main case                             3903463                             $13.00
Valve cover with access hole                                   3902605                              $49.00
SHipping Charger        $27.00
Grand total        $920.00
« Last Edit: March 19, 2010, 08:12:40 am by cubicdollars »
« Reply #18 on: March 19, 2010, 08:13:40 am »
More Picts
Offline fbody
    • firebird and camaro
« Reply #19 on: April 20, 2010, 09:03:07 am »
oh this is a sweet project. cant wait to hear how it turns out.  awesome putting the cummins in.
Offline Pullin81
  • MY86
« Reply #20 on: April 20, 2010, 07:21:46 pm »
very interested to see how all that bracketry works out and how the engine mounts work
86 gmc short box...454/th400
81 gmc crew cab dually bagged 5.9 cummins/nv4500
« Reply #21 on: June 06, 2010, 09:16:31 pm »
I will keep you up to date, the alternator and the AC brackets are really nice. I havent been working my swap much lately I took a new job and I do not have as much time :(
Offline snapdaddy
« Reply #22 on: July 12, 2010, 10:11:55 pm »
i know its been awhile since this thread was last replyed on but is there any new updates on it?
« Reply #23 on: July 13, 2010, 09:58:52 pm »
Not too much, I took another job out of town and all my projects are in storage, but this last weekend I brought back my engine and tools and set everything up in my small garage, next I plan on replacing my head gasket and all other gaskets then reassembling the engine. Over the thanksgiving break I will remove the BBC in the dually and prep the engine bay then over Christmas I plan on installing the cummins and getting it road worthy.
 My transmission is still in the shop waitng to get rebuilt and the only thing I think I am lacking are a radiator fan shroud, Throttle cable, and small parts.
I'll post some picts of the head gasket change this week.
« Reply #24 on: July 13, 2010, 10:30:25 pm »
Thanksgiving? Christmas? That's half a year away! We cant wait that long! Jk, got to make the $$ to pay for it.
Offline 1HI4x4
  • V30 Crew now a shortbed.....
« Reply #25 on: July 29, 2010, 08:11:32 am »
Where did you get your A/C and Alt. Brackets? I have bought a 12 Valve and will be trying to do the swap this winter.
Lots of good info on this thread over at 4BT swaps.
http://www.4btswaps.com/forum/showthread.php?10490-95-12v-into-88-Chevy-V30-4x4-Crew
1988 V30 Crew Cab, Cummins power, 47RH-NP205, 8" lift, 13.50x35x20 Fuel Mudders on 20x14 XD Diesels -76 offset. Soon to be repainted, seats from a 2010 Lariat to be installed.
« Reply #26 on: August 03, 2010, 09:48:22 pm »
Thats great:) I saw your post the other day, I cant wait to see it.
I got my Brackets fro Auto World in Great Falls Montana they are an awsome company and very helpfull. http://autoworldmt.com/
Everything together was pretty expensive but the parts are top quality and I was able to use my GM AC compressor and Alternator
Offline DnStClr
« Reply #27 on: August 05, 2010, 05:49:19 pm »
Looking forward to your posts cubicdollars! Have you ever checked out dieselbombers website too? Here's one of their Chevy/Cummins conversion threads.
http://www.dieselbombers.com/diesel-engine-conversions/10339-chevy-cummins-conversions-check-here-3.html
Don
87 Chevy Silverado
« Reply #28 on: November 23, 2010, 08:48:01 pm »
Hey Everyone just figured I'd throw an update together I have ben working my Dually and my stepside at the same time so I will send an update on that as well.
I removed the Cummins head and had it freshened and I re gasketed the entire engine, It only han 135000 but I didntwant to put it in and have a pan gasket leak or something. I have the fron clip off and I am in the process of removing the engine I am hoping to get it removed this weekend as planned I still havea few loose ends to tie up before and during the install portion.
1.N4500 Frankenstien tranny needs to be assembled(Dodge input shaft, Bellhousing, and case-Chevy output shaft and tailhousing)
2.Drill Engine mount's
3.Cut front to clear balancer and pully
4.purchase new throttle cable-I was told the Chevy Diesel cable will be a direct fit
5.Make Hyd line for Dodge Slave Cylinder to Chevy Master Cylinder
6.mount Dodge radiator and intercooler on front clip
It wont let me post via Webshots Check out my link the updated photos will be on page 39 and 40
« Last Edit: November 24, 2010, 09:52:01 am by Captkaos »
« Reply #29 on: November 24, 2010, 09:52:34 am »
linked some for you.  Nice progress.
