Author Topic: Engine swap  (Read 11645 times)
Offline force11b
Re: Engine swap
« Reply #15 on: May 13, 2010, 12:46:52 pm »
So when I rev the engine up good,there is no jump in the gauge pressure. This must mean it is just the switch because when I diconnect the switch the gauge jumps to the top on the readings. Even if the engine had poor pressure the gauge would move up as it get reved hard.......right??
Offline force11b
Re: Engine swap
« Reply #16 on: May 14, 2010, 02:51:22 pm »
Just got the oil pressure tested and it is over 60PSI cold. Looks like it must just be the switch.
