Author Topic: Bought truck. 25k orig miles??? or 125k  (Read 11790 times)
Offline ccz145a
Re: Bought truck. 25k orig miles??? or 125k
« Reply #15 on: May 27, 2010, 11:21:38 am »
the old heads on here will tell you to look at the brake pedal and that will tell you the milage post a pic and you should know for sure
I will take a pic tonight. The brake pedal rubber has the circle in the center that says "disc brakes" and is not worn at all...
My 79 has either 129K or 229K on it.  I am not sure.  I looked at my brake pedal and it is not wore off either.  I guess it could be 129 then, by 229 you would think it would be flat.
From what I've seen, the wear is at the corners. Not so much on the middle flat surface.
« Reply #16 on: May 27, 2010, 02:10:26 pm »
brake pedal pads can be replaced.  If it is a 91 though it should have the 6 digit speedo
