Author Topic: has anyone taken there sway bar out  (Read 25085 times)
Offline dunedigger
Re: has anyone taken there sway bar out
« Reply #15 on: June 13, 2010, 10:50:09 pm »
I put that offroad design kit on my dune truck.  I don't intend on disconnecting my sway bar but I liked what I was reading about eliminating binding issues when alternating the stock lift.  I have sway bar drop mounts but it still made sence to me that if the spring can travel farther back than stock it will fight itself with the sway bar trying to keep it forward, this kit lets it swivel and I really like mine.
Offline 86k20
« Reply #16 on: July 01, 2010, 02:41:00 pm »
ok so i drove the truck for the first time after i lifted it it has a problem with the steering it floats like crazy down the road has anyone put pinon shims in to correct this problem or does anyone now how to solve this issue
Offline Koots
« Reply #17 on: July 01, 2010, 03:03:48 pm »
I got rid of my swaybar while installing my 4" lift and i don't find it that bad at all. I also have the sway bar taken off of my 98 K1500 too so i"m a little used to it. Overall though it doesn't roll as bad as i thought it would considering i have a 6.2L, TC EZ ride front springs and no sway bar lol.
« Reply #18 on: July 01, 2010, 08:55:29 pm »
What size tires?
Offline malibu795
« Reply #19 on: July 02, 2010, 02:34:18 pm »
i did a 4" lift about a month ago.
use some 1/2 ton rear spring new front hangers and rear shackles and a cross over kit.
steering was supper sloppy, lathargice and  and generally un-responsive to inputs
found out that the longer leaf spring 52" vs 48 were flexing side to side. all tie rod end and spring bushing are brand new. with the steering i could "flex" the spring enough to move the frame 1/2" to the left or right in relation to the axle.. created all sorts of steering/tracking issues
so i built a engine cross member and track bar that went from the DS frame to the PS axle between the PS side spring mount and spindle.
adam wildman
75 K25 383/400
« Reply #20 on: July 03, 2010, 12:07:26 am »
it also could be bias ply tires they usually will flex before you get any responce in steering
Offline 86k20
« Reply #21 on: July 05, 2010, 03:59:54 pm »
do you have any pics of the crossmember you made i would be interested to see them if you do i am running 33s right now i am going to go to 37s though once the steering is solved
Offline malibu795
« Reply #22 on: July 10, 2010, 02:59:59 pm »
its rough tempary setup.. through it together so i can DD the truck
will be redoing it probly this winter.. making a bent tube cross member and incorpating these either buy buying them or makeing them
http://www.ballisticfabrication.com/Panhard-Tracbar-Frame-mount_p_1441.html
http://www.ballisticfabrication.com/Panhard-Trackbar-mount_p_1399.html
adam wildman
75 K25 383/400
Offline 86k20
« Reply #23 on: July 12, 2010, 08:09:56 pm »
Thanks for the pics
