Author Topic: Hi all!  (Read 19966 times)
Re: Hi all!
« Reply #15 on: August 06, 2010, 01:32:57 am »
Comp Cam's Thumper kits come with the cam, roller lifters, and new timing chain. I think its gear drive though. Those cams have a nice idle too. FYI.
Offline Psycho71
Re: Hi all!
« Reply #16 on: August 08, 2010, 11:46:04 am »
I had talked to some of my "advisers/gurus" on the Thumper cams. The consensus was that, for what I want, a more conventional cam will be in order. For this build, I'm not worried about a lopey idle. More concerned with an over all low end to mid range torque motor. And I kinda want a smoother idle for this one as well. Been looking real hard at the Comp Extreme Energy, Lunati Voodoo, and Comp Magnum 4x4 line of cams. If I go with a vortec set-up (hyd. roller) it will be a whole other ball of wax then. Still will be looking for the low/mid range selection of cams. Time will tell.
