Author Topic: engine cutting out under load  (Read 27895 times)
Offline cruisinc10
Re: engine cutting out under load
« Reply #15 on: August 02, 2010, 09:57:11 am »
I have the same problem but my carb needs to be rebuilt.
1986 C10 355Ci/TH350/2 inch drop/275/60/15 cooper cobra Tires/flat black w/pinstriping- sold
1984 K10 Silverado 305Ci/Th350/6 inch all spring lift/33/12.5/15 interco Trxus MT Tires/factory red and white-Daily Driver
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #16 on: August 02, 2010, 11:51:24 am »
If it's cutting out when he mashes the gas it may just be that the air flaps on the secondaries are opening too fast.  That's a simple fix that cost zero dollars.
Offline 81K10
« Reply #17 on: August 14, 2010, 12:05:13 pm »
I haven't really been mashing on the pedal, still just trying to get it running right after the engine swap. But it happens while accelerating from say 50km/h(30mph) to 80-100km/h (50-60mph) while getting on the highway as opposed to accelerating off the line.
What do I have to look at to determine if this is the problem? I like the price!
thanks
Tony.
Offline SUX2BU99
« Reply #18 on: August 16, 2010, 12:37:39 pm »
I determined my problem: a spark plug boot that melted on my #5 cylinder header and was grounding out! I could see the spark when I turned the lights out in the garage. I waited a couple of minutes and then could see it. I could see it when I turned the lights on too after I knew where to look. I had to put a shorty spark plug in and changed the wire and problem gone!! It also helped that I changed the accelerator pump nozzle head, since once side was plugged up. I think I had that problem for quite a while. Now when I punch the gas from an idle it will actually light the tires up instead of bogging down!
« Reply #19 on: August 16, 2010, 11:37:13 pm »
Amazing how things work out, especially looking at a different area. Glad you got it fixed!
Offline bobcooter
« Reply #20 on: August 17, 2010, 03:51:46 pm »
thanks
Tony.
Usually they bog down when you romp on it like when you are going to pass someone and you floor it. It'll cut out, then you have to let off some for the engine to catch back up. If it's cutting out just cruising at a steady speed it's probably not that.
