Author Topic: 86 gmc 1500 wont start after dist cap and rotor change  (Read 21229 times)
Offline misfit240
Re: 86 gmc 1500 wont start after dist cap and rotor change
« Reply #15 on: August 04, 2010, 12:22:26 am »
Thanks for all the help everyone im still working on this but have not had time to update the situation so far i replaced the cap and rotor back to the old ones and still no spark at all im going to replace the coil next because this one looks a little beat up ....
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #16 on: August 04, 2010, 12:26:34 am »
getting 12 volts at the battery (red) wire on distributor w/ key on?  As i mentioned earlier, if you get voltage to the distributor (red wire), but not out of the distributor (no spark) could be pick up coil, ignition coil, or module.
if no power to the distributor with key on, perhaps ignition switch, or wiring.
« Last Edit: August 04, 2010, 12:31:21 am by SgtDel »
« Reply #17 on: August 04, 2010, 12:20:17 pm »
Also are you testing for a spark or seeing if she will start up?
Offline misfit240
« Reply #18 on: August 04, 2010, 11:27:22 pm »
i need to test the voltage no voltmeter in my collection of tools....erg so ill have to get one also i checked for spark and there isnt one so i will check the wire wish me luck also is there a fuse for this wire?
