Author Topic: C5 Rear Disc Brake conversion with E-brake in the works  (Read 53962 times)
Offline modular93fox
Re: C5 Rear Disc Brake conversion with E-brake in the works
« Reply #30 on: January 26, 2011, 06:56:36 pm »
got the new axles in, should have the corvette brakes installed this weekend
clint
1987 5.3 4l60e Silverado - daily driver with A/C,P/W,P/L,TILT, HID projectors & 13.8" Rear Disc Brakes
A poor man buy's it twice
« Reply #31 on: January 30, 2011, 08:16:22 pm »
update: photo illustration on how I redrilled the 5x5 pattern.
printed template
trimmed timplate freehand to get rid of excess, have the butyl tape ready for next step
2 things happened in this step. 1st was to get a piece of cardboard and a pick. I placed the template on the cardboard and used the pick to punch through the center "  X  " of the 5x5 pattern. this will allow me to see where I need to place the center punch in the following step. 2nd thing that happened in this step was to apply a smear of the butyl tape. Its similar to sticky tack (the blue stuff) but its automotive grade and can be real sticky and messy when it gets real warm. I smeared 4 little spots on the tempate so it will stick to the front of the rotor.
Placed the template with the butyl tape on the face of the rotor, and then aligned the center "hub" cirlce to the center hole of the rotor, then centered the 5x4.75 pattern through the lug holes
Used a center punch and punced each of the 5x5 pattern on the dimples we made in the previous step with the pick and cardboard. A firm tap with a hammer does the trick. I will go back over it once all 5 have been done prior to drilling. I didnt take a photo of me drilling becuase thats just boring. I had a lot of worn out bits (forgot my decent set at work :( ). Basically went in steps, 1/8 so it could find the center punch mark real easy. then went up to 1/4, then 3/8, then I think i went strait to 1/2 then to 9/16. Due to my choice of wheel stud, Dorman 610-298, 2" long wheel stud, they have shoulder of 5/16, stock doesnt have one at all.... The shoulder requires you to put a chamfer on the inside of the 5x5 pattern so the rotor will sit on the axle flange rather than the stud. no big deal. I simply had a 5/8 drill bit and went down untill the drill bit made its full diameter into the rotor. Imagine when you are going from small drill bit to bigger... and when you first start drilling the beginning of the hole isnt 100% round, it takes a little bit of depth before its the diameter of the bit, thats how it looked. I did not finish the brakes, I kept on forgetting things at the parts store :( . I need to double check a few things, remove, take photos, paint, re assemble, bleed, fill axle fluid and bed the pads in.
but heres a pic of them on 17" wheels... 1.8" smaller than what I had before, the caliper is a lot smaller than the one I had before but its a bit more proportionate.. either way, it looks great, parking brake is 2 cables away :)
Offline jaredts
« Reply #32 on: January 31, 2011, 06:59:06 am »
Nice work.  I like your choice of wheels too.  It will be cool to see you finish this up and let us know how well your setup works.
Offline slammed79
  • Thou shalt not drive stock
« Reply #33 on: January 31, 2011, 05:06:04 pm »
Lookin good! I'm diggin the vette parts!
Praise the lowered
« Reply #34 on: February 03, 2011, 10:33:00 pm »
Im going to have a set of brackets cut out for my buddies nova and he might have a source on a set of used/free z06 brakes... It will give me a chance to test fit em :)
So far the brakes stops the truck just fine. The truck has had great braking from the get go.. If the weather is not poor, I will remove the prop valve guts, bleed and road test this weekend.
clint
« Reply #35 on: March 15, 2011, 06:03:26 pm »
sweet, got all 10 sets in this past week...
clint
