Author Topic: My 82 GMC 2WD budget sort bed conversion  (Read 67407 times)
Offline junkman.
Re: My 82 GMC 2WD budget sort bed conversion
« Reply #30 on: February 21, 2011, 03:43:55 pm »
Well the chassis is together and i started on the engine i found a manufacturing  date on the timing cover
1994  but I'm not sure if its a 6.2L or 6.5L it doesn't say anywhere i do know that its has a one piece rear main seal    ??? how do i tell if its a 6.2 or 6.5
I striped the engine down to long block and replaced all seals and gaskets and repainted it
also shorten my bed floor there's a post in the body section
thanks JM
Offline junkman.
« Reply #31 on: February 22, 2011, 12:48:08 am »
more pics
Offline junkman.
« Reply #32 on: April 03, 2011, 02:43:04 am »
update  here's were its now could have the cab on tomorrow
need to modify some of the fuel lines there different LB to SB
I'll keep plugging away  JM
Offline junkman.
« Reply #33 on: June 02, 2011, 02:29:18 am »
Well here's an update and some pics
Its running and Ive started shorting the bed sides more pics in a day or two  JM
Offline Grim 82
« Reply #34 on: June 02, 2011, 08:37:57 am »
Nice work. Did you find a casting number on the block to ID the motor?
Offline big bear
« Reply #35 on: June 02, 2011, 08:50:51 am »
love this truck / project.
Offline Edahall
« Reply #36 on: June 02, 2011, 10:02:51 am »
There's hardly any difference between the 6.2 and 6.5.  The 6.5 was just bored out bigger to accept slightly larger pistons.  Have you already put back on the heads?  If your goal is towards good fuel economy, you might consider installing smaller precombustion chambers on the heads.  Most likely, your heads have larger precombustion chambers which is good for power but not for fuel economy.  With smaller precombustion chambers, you'll gain about 6-8 mpg's.  Yes, you'll lose some power but you can get all the power back with a free flowing exhaust system.  I have the smallest precombusion chambers on my 82 Suburban and I'm getting a solid 30 mpg on the freeway.   I also have it geared real high with 3.08 gears and 700r4 transmission to keep the rpm's real low.
« Last Edit: October 12, 2011, 02:38:08 pm by Captkaos »
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Offline junkman.
« Reply #37 on: June 03, 2011, 12:45:59 am »
Thanks   not yet now the engines in i can't find them but i found some #'s on the heads 0137567
maybe someone know what heads i have
JM
« Last Edit: June 03, 2011, 09:37:44 pm by junkman. »
Offline junkman.
« Reply #38 on: June 03, 2011, 10:04:52 pm »
Hey thanks for the info  So is the stroke the same on 6.2 and 6.5 engines?
I found casting #'s (0137567) on the heads maybe this can help identifying the top end. I hope there small pre combustion typ.
I'm also running 700R4 and  10 bolt 3:08's peg leg    the guy i got the truck from said he was getting 24 mpg towing two jet ski trailer  on long trips
If i can get 25mpg on the hwy I'd be thrilled
« Last Edit: October 12, 2011, 02:39:53 pm by Captkaos »
Offline junkman.
« Reply #39 on: June 03, 2011, 10:43:34 pm »
Well i finished putting one of the bedsides back together the top part of the panel is flat at the seam but the middle is a little low  I'm going to start on the filler tomorrow i hope its not over a 1/8 inch thick
I'll send more pics JM
Offline Edahall
« Reply #40 on: June 03, 2011, 11:24:37 pm »
If he got 24 mpg towing two jet ski's, it's got the smaller precombustion chambers.  The engines with the larger precombustion chambers won't get 24 mpg solo.  Sounds like he made have used the old heads with the smaller precombustion chambers on the newer engine block.
The 700R4 and 3:08's will work out great for good fuel economy.
-3.73 gears
-2" Lift
Offline junkman.
Re: My 82 GMC 2WD budget short bed conversion
« Reply #41 on: June 05, 2011, 12:15:52 am »
I'm not sure if he said witch engine was in the truck. and i know he used the heads that were on the new engine
what mpg is typical with 6.2-6.5 with large pre chambered heads non turbo
Offline Edahall
« Reply #42 on: June 05, 2011, 06:53:45 am »
Typical mileage on a truck like yours with the 6.2/6.5 and large precombustion chambers is around 21 mpg.  This is assuming 1/2 ton, 2 wheel drive, 3.08 gears, 700R4 transmission and no faster than 65 mph on the freeway.  With the smaller precombusion chambers and the same truck, you would see upper 20's (26-30 mpg).  The advantage of the big precombustion chambers is an extra 35 hp but like I said earlier, a lot of that power can be restored with a free flowing exhaust.  Also remember, the trucks that were built during the days of the large precombustions chambers were built when fuel was cheap and when there was a power war between the big 3.  Dodge had come out with the Cummins and Ford had come out with their Powerstroke so Chevy had do something about it.
-3.73 gears
-2" Lift
Offline junkman.
« Reply #43 on: June 05, 2011, 10:10:12 am »
Edahall Thanks  did you post you cummins swap for the suburban
also are the casting #'s i found on both heads are these good #'s 0137567
thanks JM
« Last Edit: June 05, 2011, 10:13:50 am by junkman. »
Offline JohnnyCanuck
« Reply #44 on: June 05, 2011, 07:42:09 pm »
Man that turned out nice, well done so far.
