Author Topic: separating inner and outer bed walls  (Read 23695 times)
Offline junkman.
Re: separating inner and outer bed walls
« Reply #15 on: October 07, 2011, 02:50:29 am »
this was a lot of work !!! :P  if you can afford new parts it would be well worth it
Offline slammed79
  • Thou shalt not drive stock
« Reply #16 on: October 07, 2011, 07:36:30 am »
Turned out good. How many hours do you think you've got into it?
Praise the lowered
Offline junkman.
« Reply #17 on: October 07, 2011, 03:16:27 pm »
I don't know even after it was one piece again there was a lot of work left like filler priming and sanding and more primer and more sanding .
lets say there was over time at work i could of made money if i was to buy new parts
but i wanted to see if i could shorten it
if your looking to save money shorten the floor and get some new sides
well good luck JM
« Reply #18 on: October 12, 2011, 04:03:14 pm »
Keep posting to this. I want to put it in the Tech section.  Would love a start to finish post if you have the pics.  Let me know when you are done and I will move it...
I would also like your personal insight on this.
Offline junkman.
« Reply #19 on: October 17, 2011, 12:06:03 am »
thanks its not how to but would give some good ideas
we will start here for the bedsides
note before doing this you should have a SB floor for as a jig
« Last Edit: October 17, 2011, 12:58:56 am by junkman. »
Offline junkman.
« Reply #20 on: October 17, 2011, 01:07:44 am »
more pic;s
Offline junkman.
« Reply #21 on: October 17, 2011, 01:09:58 am »
more pic's
the first two pic's were test pieces ( white  lines )
« Last Edit: October 17, 2011, 10:45:52 pm by junkman. »
Offline junkman.
« Reply #22 on: October 17, 2011, 01:12:50 am »
more pic's
« Last Edit: October 17, 2011, 10:41:36 pm by junkman. »
Offline junkman.
« Reply #23 on: October 17, 2011, 10:40:58 pm »
more pic's
« Last Edit: November 03, 2011, 11:37:30 pm by junkman. »
Offline junkman.
« Reply #24 on: October 22, 2011, 12:31:30 am »
Captkaos its done
« Last Edit: November 03, 2011, 11:27:12 pm by junkman. »
Offline junkman.
« Reply #25 on: November 05, 2011, 12:26:21 pm »
Well its done turned out ok the finish work wasn't perfect but good for a daily driver
thanks JM
