Author Topic: new motor for my truck!!!  (Read 17313 times)
Offline westsidek20
Re: new motor for my truck!!!
« Reply #15 on: October 13, 2010, 12:15:22 pm »
sorry for my ignorance, but i don't have a trained eye yet. What kind of motor at I'm looking at exactly? is it a 350?  ???
Offline fitz
« Reply #16 on: October 13, 2010, 02:57:29 pm »
Quote
The City of Quincy Ma, used to have a second hand store that sold off used City property such as old signs, parking meters, park benches etc.
that's where I got my signs  ;)
Somehow I knew that.
Offline HOTRDCHVY388
« Reply #17 on: October 14, 2010, 02:51:33 pm »
Well you cant tell by looking at an engine what exactly it is.....like 283-400sbc they're almost Identical jus small differences like some 283's and 327's had the big 3/4'' plug instead of a the normal 5/8''. this motor started its life as a 350, but now its a 388.
"If you got em' by the balls their hearts and minds will follow"--John Wayne
Offline westsidek20
« Reply #18 on: October 16, 2010, 11:42:51 am »
nice, i have been reading on that and been thinking of taking the project of making a 350 into a 383. some sites suggest that it only involves getting a 400 crank into a 30 bored 350 block and getting more length in the pistons? is there additional steps that I'm missing?
« Reply #19 on: October 16, 2010, 12:32:16 pm »
You have to take a grinder to the block to clear the rotating assembly.
« Reply #20 on: October 18, 2010, 08:49:01 am »
what he said about the grinding part. gota make sure your crank has plenty of room
Offline westsidek20
« Reply #21 on: October 18, 2010, 03:00:45 pm »
Ok, i have seen some videos about it from Eagle cranks, they say they already prefit the cranks so very little clearance has to be done, anyways thanks for the responses. Do you use the same camshaft and heads?
« Reply #22 on: October 18, 2010, 03:25:09 pm »
if you are talking about the same heads as the stock 350, yes you can use the same heads.
« Reply #23 on: October 18, 2010, 05:49:58 pm »
if you making a stroker no not the same crank tho
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #24 on: October 18, 2010, 06:55:23 pm »
you can go on so many different suppliers like summit and have premade cranks for stroker engines.  It's a piece of cake now like putting together a puzzle.  You can get the kits with rods, pistons, crank, etc., and just throw it together.
« Reply #25 on: October 19, 2010, 11:32:24 am »
THERE is still some grinding to be done with buying stroker kits. because not every block is cast the same
Offline jaredts
« Reply #26 on: October 19, 2010, 12:01:20 pm »
From my understanding every stroker (350 to 383 or similar variations) has to have the block ground for clearance.  I don't think Sgt. Del is suggesting the kit eliminates that, but makes everything else plug and play.
Offline westsidek20
« Reply #27 on: October 19, 2010, 03:25:02 pm »
Hey HOTRDCHVY388 what kit did you use? and what would be a good deal?
I'm good at puzzles LOL  ;)
Offline boatpuller
« Reply #28 on: October 24, 2010, 06:37:51 am »
nice...........that will make it scoot.
two tone lover
« Reply #29 on: October 25, 2010, 10:42:56 am »
I  didnt buy a kit i bought a forged scat crank and scat stroker 5.7 rods. kinda pieced it together.
