Author Topic: GM crate engine questions  (Read 13844 times)
Offline eventhorizon66
Re: GM crate engine questions
« Reply #15 on: November 12, 2010, 09:03:25 am »
No prob.
Keep in mind that the Goodwrench 350 does use a flat tappet camshaft.  So you will need to break in the cam upon initial startup.  Add a bottle of GM EOS or other cam breakin lube to the oil.  Immediately bring the rpm to 2000 and vary the rpm between 2000 and 2500 rpm for 20-30 min.  It helps to have a timing light hooked up so you can get it roughly timed during the break in.  Shut the engine down and change the oil.
I didn't know if you already knew that, but it's very important for the life of a flat tappet cam.  After the break in you may wish to prolong the life of the cam by using a ZDDP additive or simply using Shell Rotella diesel oil (most diesels still use flat tappet cams).
http://www.sallee-chevrolet.com/Information/350universalgwguide.cfm
« Last Edit: November 12, 2010, 09:19:29 am by eventhorizon66 »
'85 C10 SWB 350 700R4 TKO600
