Author Topic: problems with new carb!!  (Read 9843 times)
Offline Russ130
Re: problems with new carb!!
« Reply #15 on: November 21, 2010, 08:43:40 pm »
You need to turn it counterclockwise as if you were removing it. Turning it clockwise is setting the float lower.
« Reply #16 on: November 21, 2010, 11:45:07 pm »
 you did turn the screw right? not just the nut
Offline ncguy89
    • My 4x4 Club
« Reply #17 on: December 29, 2010, 07:35:40 pm »
ok guys i havent had time to mess with the truck anymore until today. so this is an update of what i have done!! i have adjusted the floats, hooked up the electric choke, set the idle mixture screws with a vaccum gauge. now the carb is adjusted to the best of my knowledge. now the problem i am still having is the truck will pull its own wieght on flat ground but going up a hill or in my case pulling it on a trailer as soon as i touch the throttle it will pop and cut off.  it will not pull itself up a incline what so ever or better said it wont pull under a load. im guessing maybe the timing is still off? or maybe its something ignition?
1987 v20 - 350 tbi with towing cam, hummer wheels, stock otherwise
1984 chevy c-10 shortbed - kidney foundation truck (for my father)
Offline Grim 82
« Reply #18 on: December 29, 2010, 07:55:38 pm »
Sounds like it's running lean or your timing is retarded. Do you have a timing light?
Offline ncguy89
    • My 4x4 Club
« Reply #19 on: December 29, 2010, 08:09:31 pm »
i do but since i cleaned the timing tab last time it has surface rust and i cant read it anymore so i will have to clean it again with a wire brush or something.
