Author Topic: Dome light not working...  (Read 36271 times)
Re: Dome light not working...
« Reply #15 on: December 04, 2010, 07:11:19 pm »
try cleaning them and see if it helps.
Offline tylermaster195
  • Buy it cheap, fix it up for less
« Reply #16 on: December 05, 2010, 01:55:01 am »
I will.
Offline Tazman
« Reply #17 on: December 06, 2010, 04:26:51 pm »
That wire runs along the door bottom ,it is possible that you could have a short in it.It could have been pinched and worn through.Just something to check on.
God BLESS AMERICA
« Reply #18 on: December 08, 2010, 08:43:24 am »
The wires that run through the bottom are very corroded. Must be were I am getting my resistance. I will replace those this weekend if I have time. Let you know the results. And cleaning the contacts didn't help. Wheres the ground for the bulb?
Offline 1980c10
« Reply #19 on: December 08, 2010, 11:14:40 am »
btw you can test resistance with your wires too
« Reply #20 on: December 08, 2010, 11:31:00 am »
You mean with the VOM?
Offline 1980c10
« Reply #21 on: December 08, 2010, 05:46:38 pm »
yup, it should read the same or very close to what it reads when you touch the leads together or zero depending on caliberation, the higher the number the worse the wire. you can also check your grounds the same.
