Author Topic: 4x4 Shifter  (Read 42300 times)
Re: 4x4 Shifter
« Reply #45 on: December 31, 2010, 04:39:58 pm »
I dont remember what size, but you can use a drill bit to guarantee the right size.
Re: 4x4 Shifter
« Reply #46 on: January 01, 2011, 12:37:25 am »
my shifter on my 205 screws up sometimes also if I put it in 4low it will sometimes not engage the rear and only the front will turn kind of weird having a front wheel drive truck in the mud. But mud is my problem its kind of glues the linkage together just have to clean it out
Offline Yamaha74
Re: 4x4 Shifter
« Reply #47 on: January 01, 2011, 07:15:03 pm »
I got the shifter assembly moving both the bars now so hopefully tomorrow I will start it up and see if the 4wd works.  I also did check the adjustment and it seems like it is lined up perfect so I didn't need to adjust it
Offline KY..Rob
Re: 4x4 Shifter
« Reply #48 on: January 02, 2011, 02:17:15 pm »
Good Deal! I would check the fluid level also. Top it off with some 10w40
Offline Yamaha74
Re: 4x4 Shifter
« Reply #49 on: January 03, 2011, 10:16:46 am »
Good call.  I will check the fluid level and top it off if needed.  10w-40 is what is recommeded?
Re: 4x4 Shifter
« Reply #50 on: January 03, 2011, 10:42:41 am »
Yes 10-40
Re: 4x4 Shifter
« Reply #51 on: January 03, 2011, 08:27:47 pm »
I would drain it all and put fresh 10w40 in. Never know what the previous owner used. Plus, what truck doesnt like fresh fluids?
Offline Yamaha74
Re: 4x4 Shifter
« Reply #52 on: January 03, 2011, 08:37:54 pm »
How much oil does it hold and does anybody use any particular brand of oil?
Re: 4x4 Shifter
« Reply #53 on: January 03, 2011, 10:57:39 pm »
