Author Topic: timing/idle  (Read 14966 times)
Offline 1979C20
  • Kyle Taulton.
Re: timing/idle
« Reply #15 on: December 09, 2010, 11:46:18 pm »
I bought the mixture screw tool. I turned them in all the way, left side was about 6 and a half turns out. Right was about 7 turns out. Got it to idle at 4 and a half turns out. Running AMAZING now. And, when I turn the distributor cap counter clockwise, looking at it from above the engine starts to stall. No pinging. And, correct me if I'm wrong, pinging sounds like beans rattling in a can, right?
Offline 1979C20
  • Kyle Taulton.
Re: timing/idle
« Reply #16 on: December 09, 2010, 11:51:57 pm »
And, when I turn it counter clockwise, the rpms go up.
Offline Grim 82
Re: timing/idle
« Reply #17 on: December 10, 2010, 08:35:36 am »
You lost me there.  What is the timing light telling you? Set it to 8-12 BTDC and see how it runs.
Offline 1979C20
  • Kyle Taulton.
Re: timing/idle
« Reply #18 on: December 10, 2010, 12:34:05 pm »
What does 8-12 degrees look like on a stock timing mark, and I know the balancer hasn't slipped.
Offline Grim 82
Re: timing/idle
« Reply #19 on: December 10, 2010, 01:24:06 pm »
Doesn't your tab have numbers on it? You might need to take some emery cloth to it to read them. I just meant set it a little more advanced than factory spec. Like 8, or 10, or 12 or so.
