Author Topic: 2wd to 4wd conversion  (Read 54999 times)
Re: 2wd to 4wd conversion
« Reply #30 on: December 17, 2010, 10:15:36 am »
you cant buy the whole truck from the yard just parts of it ex. frame and axles. then if you do buy the frame don’t worry about cutting and use that frame
Offline 1979C20
  • Kyle Taulton.
« Reply #31 on: January 28, 2011, 01:40:28 am »
So, after seeing the 2000 gen engines and trannys swapped into our trucks, would it be possible to swap engine, tranny, transfercase, front dif, control arms, spindles, axleshafts for the IFS ont out frame?
Offline thirsty
    • Suitor's Garage
« Reply #32 on: January 28, 2011, 02:14:16 pm »
this is my daily driver and I cant have it sitting.
I bet that putting IFS in a squarebody would be quite a lengthy process.
Kinda like making applesauce from oranges.
« Last Edit: January 28, 2011, 02:17:57 pm by thirsty »
Offline 1979C20
  • Kyle Taulton.
« Reply #33 on: January 28, 2011, 03:12:22 pm »
Well, im just curious if its possible. Seems like a cool concept. That would be a bad truck!
« Last Edit: January 31, 2011, 09:07:58 pm by Captkaos »
Offline ccz145a
« Reply #34 on: January 28, 2011, 08:01:02 pm »
It would probably be easier to put the sq body on the newer chassis.
Offline 1979C20
  • Kyle Taulton.
« Reply #35 on: January 31, 2011, 12:27:06 am »
Would the front suspension, steering, axle, etc. from this truck work on mine? I figure, talk to the guy and offer him 150 from the whole front suspension assembly and then I'd have my starting point for my conversion.
« Reply #36 on: January 31, 2011, 09:09:23 pm »
newer trucks have the t-case drop on the opposite side don't they.
« Reply #37 on: January 31, 2011, 10:17:37 pm »
You would need a left side front output T case if you were to swap in IFS. As far as putting a solid front axle in and just driving that way for a bit, you will need to swap in the rear spring hangers / shackles along with it. If you leave the two wheel drives ones in it your nose is going to be a few inches higher than the rear.
