Author Topic: Hella 7" Conversion Lights with Relay and Xenon Upgrade  (Read 19643 times)
Offline bobcooter
  • 1979 Scottsdale C-20
Re: Hella 7" Conversion Lights with Relay and Xenon Upgrade
« Reply #15 on: January 12, 2011, 08:12:08 am »
I see now. Good idea.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #16 on: January 12, 2011, 11:25:49 am »
About the relays...
Before I did the relay upgrade, but on the new bulbs, I checked the Voltage AT the headlight while the truck was running.  While the rest of the truck was getting 14.2V,  AT the headlight I was only getting 12.9V.  And my stock wiring and connections were in really good shape.
Now after the Relay upgrade I get the full 14.2V at the lights.  My new upgraded alternator charging wire goes directly to the battery +  so that's where I put the main 12v+ feed to the relays.  So in essence, it might as well be right on the alternator, but it has a shorter wire.
I just used 16ga. wire for everything except the Main 12v+ feed to the relays themselves.  I used 12ga there.  Used one 12ga wire and split it right before the relays, and used one 30A fuse in the line before it split.
Offline jackjeckel757
« Reply #17 on: January 12, 2011, 11:35:25 am »
Looks great!! Its not those blue headlights I can't stand either...
  • Z62 ON-ROAD
« Reply #18 on: January 19, 2011, 04:50:27 pm »
My wire loom showed up so I got the wiring all tidied up and coverd.  looks much better!  I bought a wire loom kit with 25ft. of 6 sizes so I did the whole engine bay, replaced everything that was gone, red, or cracked.
Headlight Harness
Everything else
Before
After
Offline Grover 1
« Reply #19 on: January 19, 2011, 07:51:23 pm »
Looks great, what an improvement!  Thanks for sharing all the pics.
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
And here I sit so patiently
You have to pay to get out of
Offline eventhorizon66
« Reply #20 on: January 19, 2011, 07:54:33 pm »
A little convoluted tubing goes a long way.  Good job.
'85 C10 SWB 350 700R4 TKO600
  • Z62 ON-ROAD
« Reply #21 on: January 19, 2011, 10:19:30 pm »
Thanks Fellas.  Yeah I been putting that off for 3 years because the loom is so danged expensive if you get it at the parts store.
If anybodys interested, here's the loom I bought.  It's as good a quality stuff as anything else I've ever seen.  I'm gonna buy more of the smaller sizes on friday from the same guy.  It's awesome stuff!  a note though, if you do buy it and the box shows up and you're missing a couple of sizes...  they're inside of the bigger sizes to save shipping space, yeah i almost sent a nasty email to them... ;)
It's $33.70  for 25ft. each of sizes 1/4, 3/8, 1/2, 5/8, 3/4, 1".   The same guy also sells 100ft single rolls for approx $22 a roll.  Beats the pants off advance auto parts prices.
http://cgi.ebay.com/ebaymotors/Black-wire-loom-SUPER-SAVER-assortment-6-sizes-150-feet-/380257008985?pt=Motors_Car_Truck_Parts_Accessories&hash=item5889157d59#ht_3609wt_1039
I also bought these wire ties to go with it....  they're HIGH quality stuff too.  I'm buying more of them friday too.
http://cgi.ebay.com/600-PCS-8-Black-Cable-Wire-Tie-40-Lbs-Zip-Nylon-SALE-/190390734231?pt=LH_DefaultDomain_0&hash=item2c542c0d97#ht_1750wt_1019
« Last Edit: January 19, 2011, 10:24:31 pm by 78 Chevyrado »
Offline 76k104x4
« Reply #22 on: February 06, 2011, 10:40:48 pm »
any body got a diagram of how to make the relays or whatever you gotta do i know nothing about electricity or wiring stuff up thanks
