Author Topic: 1979 gmc high sierra  (Read 19500 times)
Offline KY..Rob
Re: 1979 gmc high sierra
« Reply #15 on: December 30, 2010, 11:50:35 pm »
I see, My trucks a 4 speed also. Did you try bumping the starter as stated above? You can do it with a screwdriver also. This might help to track down where the problem is, Could be in the key switch or a fusible link.
Let us know, I'm curious my self.
Offline 79HIGHSIERRA
  • heartbeat of america
« Reply #16 on: December 31, 2010, 01:55:06 pm »
ok well i had swapped out the collumns in it too cuz the old one was stripped out (from previous owner starting with a screwdriver) and i hooked every thing back up and remounted it to the collumn as it was when i took it apart and if it was something in the collumn would i have power when i turn the key on or no?
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #17 on: December 31, 2010, 02:37:55 pm »
you could still have power when key is still half on.  However your ignition switch could still be bad when trying to turn the key all the way.  I am not sure about the neutral safety switch now that we have learned your vehicle is a standard trans.  I don't know if there is a switch to prevent it from started while in gear and where that would be.  Perhaps a clutch switch or something.
Just try overriding the whole shebang like we discussed.  That'll narrow down your problem.
Offline Grover 1
« Reply #18 on: December 31, 2010, 04:12:21 pm »
That's cool Andy, shebang.  I've heard it used but never seen it in print!
1978 C-10 SWB
1986 K-10 SWB
1975 C-10 SWB
And here I sit so patiently
You have to pay to get out of
Offline 1980c10
« Reply #19 on: December 31, 2010, 05:17:40 pm »
On the back of the starter jump the little nut to the big nut and the starter will engage and turn over if not the problem is in your starter, battery cable or battery. btw make sure it is in nuetral and tires blocked with your park brake set.
« Reply #20 on: December 31, 2010, 07:21:43 pm »
ill try that and keep ya posted thanks for everything guys i greatly appreciate all the tips and help and when i get a decent camera ill post pictures of the truck
