Author Topic: New Camper special...  (Read 23294 times)
Offline Jim Rockford
  • Banned
Re: New Camper special...
« Reply #15 on: January 18, 2011, 06:38:55 pm »
well since The 73 is so rusty Out comes the engine and I'm gonna remove everything I can salvage  or posibly sell for parts and the engine is going in the 80 ...pulled it out tonight.
While I was turning the engine over to position it at NO.1  I noticed some slack in the timing chain, After checking it , looks to have about 10 degrees of slop..lol So it will get a gasket kit and a new chain might install a set of 305 H.O. Heads I got laying around.
« Last Edit: January 18, 2011, 07:18:45 pm by Jim Rockford »
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
Offline thirsty
    • Suitor's Garage
« Reply #16 on: January 18, 2011, 07:26:27 pm »
Don't forget your new Generals ;D
  • Banned
« Reply #17 on: January 19, 2011, 06:16:58 am »
No worries there, I hate o part this thing out, but the rear frame and body is just too far gone, and I'll never really ever need that front dana 60 .
  • Banned
« Reply #18 on: January 21, 2011, 07:11:14 am »
Well the timing chain was worn out, So I installed a double roller chain, and bought all the gaskets to seal her up and Slowly getting the block clean, Installed a new oil pump and screen and check the condition of the bearing, This engine despite how it looked on the outside  it really clean  and has VERY low wear , bearings look like they where just installed and the bores still have the cross hatching. After I get it installed into my 80  it will be worthy of some vortec heads in the future.
After I get the intake resealed I'm gonna finish degreaseing the block and paint the rest black. I hate orange and blue engines.
« Last Edit: January 22, 2011, 10:17:54 am by Jim Rockford »
Offline Grim 82
« Reply #19 on: January 21, 2011, 09:14:21 am »
That one piece pan gasket looks like the real deal.
  • Banned
« Reply #20 on: January 21, 2011, 09:35:07 am »
Yea  read alot of reviews that say they work great, ANYTHING is better than the oil 4 piece setup. Can't wait to see how that new double lip rear main seal holds up. Now I just need two good exhaust manifolds.
« Reply #21 on: January 21, 2011, 11:51:29 am »
Those look like original plug wires haha. Thats good to know that the rotating assembly is in great condition.
  • Banned
« Reply #22 on: January 21, 2011, 12:04:52 pm »
even had the old green striped AC plugs...
  • Banned
« Reply #23 on: January 21, 2011, 06:41:00 pm »
« Last Edit: January 24, 2011, 03:17:40 pm by Jim Rockford »
« Reply #24 on: January 22, 2011, 08:19:24 pm »
     Jim I feel your pain, my 74 k10 I bought the p.o. welded 1/4" plate basically all over the cab floors and up the inside of the cab corners and kick panels.  Was going to remove it and fix it right, but he really welded it and warped everything else.  So I dragged a 78 k10 home tonight for the body.  (someone tried to steal the 78, they got the transmission and transfer case, radiator and driveshafts ) and basically trashed the steering Column.
  • Banned
« Reply #25 on: January 31, 2011, 07:10:19 am »
Note the nice new China made exhaust manifolds... I was pissed cause the Ebay ad said they had the heat  shield, and when I got it ...It didn't , so I tried chatting with a rep online and he kept telling me it never said that , even after I gave him the link AND quoted the exact phase from the ad, so I told him screw it, I'll wait 7 days and leave negative feedback.  I really didn't care it was not on there , its just the fact that is stated it came with one.
Bell housing after a couple of hours with wire brushes and a dental pic. Painted with Cast Aluminum paint
Cast Iron paint
I like this cast Iron paint, It matches almost perfect with the brand new Manifolds
Just about ready to swing in
New clutch and pressure plate.
Nice clean bell housing
And she's in.. It was a pain trying to get the trans lined up with the bellhousing, So I'm back and forth under the truck trying the get everything line up Then I see the frigging transmission isn't even bolted to the crossmember...RRRRRR After a few choice words I got a bolt in the trans mount and lowered the jack from the front of the trans and it slipped right in....
« Reply #26 on: January 31, 2011, 07:21:58 am »
     It looks good, you are making real progress.
Offline jaredts
« Reply #27 on: January 31, 2011, 08:41:11 am »
Nice work, Jim.  Its definately worth the extra work to clean up and paint everything.  Thanks for sharing the pics.
