Author Topic: Overheating Problem  (Read 13325 times)
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
Re: Overheating Problem
« Reply #15 on: January 14, 2011, 06:17:41 pm »
sure your temp sensor works?
« Last Edit: January 14, 2011, 06:21:19 pm by SgtDel »
Offline Slammed83
« Reply #16 on: January 14, 2011, 07:34:54 pm »
I dont know, Its an equus gauge. I am going to flush the radiator and see if that helps
« Reply #17 on: January 14, 2011, 08:26:44 pm »
Something is wrong if it was 190 in august, but 220 in winter...
Offline Slooby
« Reply #18 on: January 14, 2011, 10:18:51 pm »
Have you checked your fan clutch, being as you say the temp drops when driving sounds like the fan clutch not engaging right.
Offline Slammed83
« Reply #19 on: January 14, 2011, 10:56:12 pm »
No i have not, I will in the morning. Im just trying to eliminate possibilitys
Offline Jim Rockford
  • Banned
« Reply #20 on: January 17, 2011, 09:06:00 am »
yep. 90% of the time if your truck runs warm at idle and cools off after you start driving its a sign the fan clutch is going or gone bad. Avoid the urge to install a flex fan , they are junk , just get a good replacement fan clutch.
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
Offline benzesrule
« Reply #21 on: January 17, 2011, 09:14:27 am »
I had this same problem om my 84 k10 but only when the snowplow was installed. When the truck was hot, I spun the fan and it turned very free. I replaced the clutch fan and I have not had the problem again. No matter where I raised the plow, all the way up or lower, My truck never overheated since.
Offline Layne
« Reply #22 on: January 17, 2011, 01:55:11 pm »
I had a 92 s-10 with the iron duke and it had a bad fan clutch. Sounded like an airplane. Anyway, I was 16 and didn't know too much car stuff and it zoomed right off the water pump and into my rad. That was a fun day....
