truck pulls to the right goin down road.
Topic: truck pulls to the right goin down road. (Read 15955 times)
Big Blue 87
Re: truck pulls to the right goin down road.
Reply #15 on:
January 20, 2011, 07:32:12 am »
ok thats what i was wonderin about all that can be adjusted. the truck has new and like new ball joints
Blue 1987 Chevy 1/2 ton truck 4x4..fuel injected 350..4 inch Rough Country lift..36x12.50x15 Super Swamper TSL/SX tires
Big Blue 87
Reply #16 on:
January 20, 2011, 03:28:05 pm »
could the sway bar have anything to do with this
Reply #17 on:
January 20, 2011, 05:08:25 pm »
You have tie rods to adjust. One thing you can do is take the tires off put a couple lugs back on to hold the rotor back on and measure the front of the rotor on the left side to the right side then do the same for the rear see what's different
Reply #18 on:
January 20, 2011, 05:12:13 pm »
Also maybe the axle nuts on one side or the other could be to tight of lose
Big Blue 87
Reply #19 on:
January 25, 2011, 08:06:23 pm »
well i got the truck fixed. took it to an alignment shop. toe was good jus the steerin wheel needed to be centerd up they adjustd the draglink. drives purty good now considerin way it was
