Author Topic: Coolant question  (Read 10342 times)
Offline thirsty
    • Suitor's Garage
Re: Coolant question
« Reply #15 on: February 06, 2011, 11:26:16 am »
The reason I asked about the t-stat was because of racing at local short tracks. I've seen alot of cars without stats overheat. We always cut the center out of them to slow the water down and keep it in the motor just a little longer. We found that not enough heat was getting transfered to the water at high rpms. So I was thinking maybe it was stuck open or maybe your old radiator is getting gunked up and not getting your coolant temp down before it goes back to your engine. Hope you find out what it is.
I hate to even bring this up but did you narrow it down to your coolant system and rule out a head gasket?
Offline Da67goatman
  • Burban
« Reply #16 on: February 06, 2011, 11:48:11 am »
I was assuming that since the motor has less than 500 miles on it the head gaskets would be intact still.  and the coolant is clean ad the oil was clean when I changed it 100 miles ago, no mixing.
<Pitcrew>
