Author Topic: 1980 Chevy Silverado Limited Edition  (Read 32058 times)
Offline BigRuss
Re: 1980 Chevy Silverado Limited Edition
« Reply #30 on: February 28, 2011, 07:01:57 pm »
How do capt and vill pay for it all? ;D
gotta learn to budget brotha.... im building my C10 on a super cheap budget (less than 2 grand) soo just keep it within your budget and you can pull of dang near anything
if your gonna be dumb you gotta be tough
Offline 87454westernhauler
« Reply #31 on: March 01, 2011, 09:44:15 am »
I know what you mean :D
79 gmc c20 350 th350
78 k1500 4x4 350 th350
« Reply #32 on: March 02, 2011, 09:09:35 am »
this think is a MUD DIGGER! ;D the frost went out westerday and my dad got the 87 r30 454 dually western hauler baried up to the running bords in our yard with a flat bed on it. the idiot thought that he could drive it through an area in our yard that has never had grave befor and went straite down! >:( so I threw a chain on it with the 80 siverado 1/2 ton 2 wheel drive and pulled it staite out with no issues on the first try!! ;D covered the hauler with mud ;D I was suprised it did what it did!
« Reply #33 on: March 05, 2011, 03:57:02 pm »
So I looked at the carb last night, is there suposed to be a mixture screw in the front middle of the quadrajet carb? I have bean degreasing the motorand it looks like there is a spot where a gas/air mixture screw is suposed to go, but is missing. Not shure where the ajuster screws are located at.
Offline jaredts
« Reply #34 on: March 05, 2011, 05:26:46 pm »
There's two and sometimes they are under factory installed plugs if no one has removed them.  They are idle mixture only (not the entire range).
« Reply #35 on: March 08, 2011, 07:14:36 am »
where abouts should they be located at. would a quadrajet off of a 454 work on a 350 Sb?
Offline jaredts
« Reply #36 on: March 08, 2011, 12:28:20 pm »
The plugs usually blend in and are hard to see.  They are at the front bottom of the carb., basically against the gasket.  One on the left, one on the right, something like 3" or 4" apart.  I have never had to pull the plugs out of one, but I think you use a self tapping screw and pull them out with channel locks or something similar by pulling on the screw.  A slide hammer would be ideal.  A 454 quadrajet could work, but it will need a lot of tuning.  I suspect you would have to change the jets and metering rods in addition to normal adjustments.
« Reply #37 on: March 09, 2011, 05:38:24 pm »
finaly got some pictures of it. heres a link to them and some of my other projects.
https://picasaweb.google.com/colonescoffapres/1980ChevySilveradoLimitedEdition#
87454westernhauler
« Reply #38 on: April 19, 2011, 04:58:00 pm »
Finally attempted painting my door panels a couple of weeks ago and look nice. wound up sanding them down, priming them 2 or 3 time and them painting them black, I may try to paint them red again but for now black looks way better than faded out dry rot. Here is a link to a picture of them back on the truck.
https://picasaweb.google.com/colonescoffapres/1980ChevySilveradoLimitedEdition?authkey=Gv1sRgCNHw1Imgy8-dZA#5582222406931504530
« Last Edit: April 21, 2011, 11:06:42 am by Captkaos »
