Author Topic: Did my np203 originally come with a hurst shifter in my '74 K20  (Read 29022 times)
Re: Did my np203 originally come with a hurst shifter in my '74 K20
« Reply #15 on: August 17, 2011, 11:58:12 pm »
i cant see hurst putting a shifter where the stock boot covers half their name
Offline jdl71
« Reply #16 on: August 30, 2011, 09:46:38 pm »
Is it possible that Hurst did make the shifters for GM, just without the Hurst stamping? Is it also possible that GM had a shortage and had to use some with Hurst stamped on them as it seems these posts are all about '73-'74 trucks?
« Reply #17 on: August 31, 2011, 08:20:56 am »
there was something i was reading about dealers doing something to post 74 chevy's transmissions
« Reply #18 on: August 31, 2011, 08:39:37 am »
it was about headers but this is it
« Last Edit: September 15, 2011, 10:09:49 am by Irish_Alley »
Offline Cabcorner
« Reply #19 on: September 15, 2011, 05:44:26 am »
   I did an Ebay search on Hurst shifters and not only the handle but the 203 shift box looks like a Hurst design . I wonder if not GM maybe New Process had a collaboration with Hurst.
« Reply #20 on: September 15, 2011, 10:11:58 am »
sorry i posted the wrong pic lol. but look at letter "c" now like i said it had to do with headers but seams weird that the same year trucks might also have a hurts shifter
Offline Jason S
« Reply #21 on: October 11, 2011, 11:47:52 pm »
Doing a little bit of research on the subject has netted the following:
There were apparently two transfer case shifter designs for the NP 203; one was a Hurst unit that was riveted together and the other was the GM that was mostly bolted together.
The Hurst shifter handle (i.e., the chrome shift arm through the floor could be found on Hurst and GM units.
There is a way to twin-stick the GM NP203 Transfer case shifter using the parts from two shifters.
Offline jdl71
« Reply #22 on: October 12, 2011, 08:52:58 pm »
I'm afraid I don't see the advantage in twin sticking a 203. You've already got 2LO. What other combination can be gained from this?
BTW I'd love to see some more pics of the trucks in your avatar. Nice looking rigs.
Offline Cabcorner
« Reply #23 on: October 15, 2011, 04:43:33 pm »
                       I did the twin stick conversion on my 203 shifter . It was fairly easy and shifts much easier . Here's a link on how to do it
.http://www.wheelindixie.com/forums/showthread.php?970-NP-203-twin-stick-build
« Reply #24 on: October 15, 2011, 05:47:13 pm »
     Thanks for the link, I might have to think about doing that to my 203.
Offline Jason S
« Reply #25 on: October 18, 2011, 07:55:07 pm »
[/quote]
Often, the NP203 transfer case shifter can be a "finicky piece of work."
 By eliminating some of the junk in the shifter box (especially if its worn out, corroded or just plain muddy), you can have a shifter that gives you a positive engagement into whatever range or drive selection.
RE: BTW:  Your comment is much appreciated, Please see the members rides section for postings.
« Last Edit: November 02, 2011, 07:20:09 pm by Jason S »
