Author Topic: 1987 Chevy R30 CCLB Turbocharged 5.3 in - next up odds and ends  (Read 141356 times)
Offline roadrage41
Re: 1987 Chevy R30 CCLB Union Pacific edition
« Reply #30 on: March 03, 2011, 01:33:49 am »
So am I, not quite as well paid though. Still looking into the possibility of a Turbo cam or just rolling with a zo6. Want 550 to the wheels if i can get it there without 12 pounds of boost, even better.
Offline roadrage41
« Reply #31 on: March 05, 2011, 06:12:31 pm »
MOAR TOYS!
need fuel line, fuel pump, boost controller, blow off valve, and to figure out the cam situation, and some decent freaking weather. (and if i can swing it a 2 step and a line lock but thats on the hush... lol)
decided to swap the rear to run disc brakes and after that its just miscellaneous bits and pieces. (weight savings!)  :D
Offline roadrage41
« Reply #32 on: March 15, 2011, 08:09:50 pm »
actual progress! then we ran out of light.  :(
Offline mats1985gmc
« Reply #33 on: March 16, 2011, 11:51:19 am »
do I see a chevelle,
Offline roadrage41
Offline mats1985gmc
« Reply #35 on: March 16, 2011, 05:58:37 pm »
Beautiful. My fav Muscle car!
Offline 87454westernhauler
« Reply #36 on: March 18, 2011, 04:17:01 pm »
I like the trucks beter :P
79 gmc c20 350 th350
78 k1500 4x4 350 th350
Offline roadrage41
« Reply #37 on: March 20, 2011, 03:24:36 am »
popped the shocks off tonight, did some test fitting of the turbo and the hot side piping on a mock up motor, waiting to hear on some fuel tank brackets.
belltech has seriously given me the wrong part number for the c-notch 3 times. about to flip it, order a thorbecke and call it a day. my bed isn't pristine anyway.  :-\
Offline bobcooter
  • 1979 Scottsdale C-20
« Reply #38 on: March 20, 2011, 07:53:12 am »
At least they are serious about giving you the wrong part number. ;)
Offline roadrage41
« Reply #39 on: March 20, 2011, 10:04:14 pm »
i know, they're killing me, how do you not know the correct part number for a part you manufacture and sell.
all the dually guys are being quiet on what the correct number is and the part number is stamped on the darned thing. half the crew cab square dually's on the road are lowered.
got the squid cut off today, got the fronts of the leafs unhooked, all the brake stuff cut.
pretty much cut the u-bolts off, remove some springs, and the rear end will be flipped. oh and remove the stupid bumpstops because i dont have the correct c-notch.
look ma no squid!
« Last Edit: March 21, 2011, 01:42:14 am by roadrage41 »
Offline roadrage41
« Reply #40 on: March 25, 2011, 04:27:42 am »
all brake parts in transit, new fuel tank brackets in transit, snow in transit.
Dear winter, GO AWAY. Thank you.
need to do several hours of grinding on that there frame. supposed to be decent monday. supposed to be.
maybe ill put my fuel tank together.
Offline Jims86tpisub
« Reply #41 on: March 25, 2011, 04:34:11 pm »
That frikken muffler was huge!
Jim
1986 K10 Suburban
Tuned Port Injection
193 Heads
Comp 260H cam
700r4 Raptor
Single exhaust with 2 Magnaflow Mufflers inline
Offline roadrage41
« Reply #42 on: March 28, 2011, 08:19:56 pm »
hmm brake brackets came in, they look pretty legit.
gonna opt to just run with no e-brake, the caddy setup seems viable, just too much expense for the loaded calipers, et al.
flip kit that was guaranteed to fit my truck is waaaaaay off. closest thing i've found is that it might be for a dana 80 ???
trying to find out if a c20 kit will work, so far noone has one in stock to take actual measurements. hoping lowering the front goes smoother than this.
Offline roadrage41
« Reply #43 on: March 31, 2011, 08:38:05 pm »
assembled the new gas tank tonight out of disgust for the lowering debacle. went disturbingly well, everything fit perfectly. even came with the correct adapter to plumb the walbro into the chevy wiring. i kept waiting for something to be wrong, what a relief.
walbro looks factory -
paint on the ebay brackets is drying, paint the back's tomorrow. hopefully get it all back under the truck saturday.
ordered a c-20 kit, western chassis says it'll probably fit. hopefully be here relatively soon. ready to get the rear back together so we can get the front dropped and the crappy old 350 yanked out.
« Last Edit: April 01, 2011, 07:13:55 am by roadrage41 »
Offline roadrage41
« Reply #44 on: April 05, 2011, 06:25:08 am »
And it goes a little sumphin like this.
flip kit needs to show up, im ready to do some burnouts.
