Performance
my cheap exhaust system!
Topic: my cheap exhaust system! (Read 20621 times)
autofreak
Re: my cheap exhaust system!
Reply #15 on:
March 09, 2011, 10:56:49 pm »
the bolt flange on the pipe side is welded to the exhaust pipe so about 1 1/2-2" of pipe slides into the collector. the flange on the header is left loose as to line up the bolts. it is 3" pipe
txchainsawgogi
Reply #16 on:
March 10, 2011, 06:58:10 pm »
The headers look cool. Got everything together and started to bolt the collector flange to the exhaust pipe when... I noticed a "straight" pipe isn't going to work...not with these headers.
Tomorrow ill take the pipes back to the local muffler shop and use their bendy machine to put a slight Z bend to raise it so it won't drag on the ground when I put 15"s on it.
Pix and a video for tad tomorrow![youtube=425,350][/youtube]
txchainsawgogi
Reply #17 on:
March 12, 2011, 10:33:54 pm »
how long is a normal period for it to smoke? is there like... a break in period for the headers?
screamin86
Reply #18 on:
March 13, 2011, 03:51:08 am »
Well how long has it been smoking? Generaly whatever coating(paint) is on the header plus the rest of the exhaust will burn off and all the oils from your hands and such and will stink awful lol
86 ta:lm7 hot cam boltons
Tad.
'86 SWB
Reply #19 on:
March 13, 2011, 08:03:01 am »
Did you use gasket glue? I got my headers on yesterday and it smoked for a good 20 minutes till all the gasket glue was gone. After that, it's good.
txchainsawgogi
Reply #20 on:
March 13, 2011, 04:53:23 pm »
not a lot of smoke, and some of it is blow by from worn rings
i took a video but man, my cell phone's speaker is crap. i'll charge up my girlfriend's camera and maybe it'll sound better.
1979C20
Kyle Taulton.
Reply #21 on:
March 13, 2011, 04:59:15 pm »
Personally, I went over the crossmember on the driver side and under on the pass side. Theyre paralell to eachother, to the frame rails, and to the ground.
Tad.
'86 SWB
Reply #22 on:
March 13, 2011, 07:23:35 pm »
It's all good, bud. Does it sound good?
txchainsawgogi
Reply #23 on:
March 13, 2011, 07:27:03 pm »
yeah sounds a lot better than the rusted out stock setup. surprisingly not as loud as i thought. pretty low until you get on it, then its a rumbley rappy sound.
Tad.
'86 SWB
Reply #24 on:
March 13, 2011, 10:40:06 pm »
I can't get over the idle with open headers and no exhaust... Sounds beautiful!!!
Blazin
Blazin new trails!
Reply #25 on:
March 13, 2011, 10:43:36 pm »
I use a donut gasket that you would find between a manifold and a Y pipe flange. Juts take the collector to the parts store and match up the size. You will need longer bolts as a the donut will be about 1/2" to 3/4" thick and leave that gap between the flanges.
Tad.
'86 SWB
Reply #26 on:
March 17, 2011, 09:39:27 pm »
Had the shop install my exhaust today. Turn downs before the rear axle pointed right at the ground. I love how to ground shakes when you stand beside it. And the exhaust is quieter than my old trues. I think I'm starting to take a liking to it better than my old exhaust. It's a lot deeper, but not as loud. I've been readin on the internet and a lot of folks are saying how the Thrush Turbos take a while to break in and after that they sound like flowmasters. We'll see!
1979C20
Kyle Taulton.
Reply #27 on:
March 18, 2011, 01:54:08 am »
If you want to louden up your exhaust a bit, fatten your carb up. I run my truck a little rich because it makes my cam louder at 600 idle.
txchainsawgogi
Reply #28 on:
March 18, 2011, 02:27:29 am »
Until I have a new intake and came lined up I'm leaving the carb stock. I have no idea how to replace a cam shaft though.
1979C20
Kyle Taulton.
Reply #29 on:
March 18, 2011, 06:00:53 am »
Ive got a bone stock engine. Stock bore stock intake stock carb, stock heads, etc. the thing that isnt stock in my engine is the cam. Just turn the mixture screws on the front of the carb about a quarter to a half turn clockwise and crack the trottle to make your adjustments set and youll notice your exhaust is louder. Not saying you have to, just my personal experience. As far as the cam swap, I put my cam in while rebuilding. So I dont know how to do it with the engine in the truck!
Performance
