Author Topic: 750 dbl pumper  (Read 19310 times)
Offline 305chevy c-10
Re: 750 dbl pumper
« Reply #15 on: January 14, 2012, 08:18:10 am »
so re-jetting this with smaller jets or squirtters won't work.i know i would get snappier throttle response from a small carb
Heartbeat of America yesterday's cheverolet
18T5C10
Offline chevymanrob
Re: 750 dbl pumper
« Reply #16 on: January 15, 2012, 08:45:54 am »
750's are for big blocks.  Period.
LOL!!! sounds as if the 950HP wasn't be a good choice on my old 406. wheels up and 11s seemed to work out though. but in reality a 750DP is alot of carb on anything but a SERIOUS engine (think 375ish horsepower as a start).
ex G-body drag fan. best was 11.86 on a 93 octane SBC street car.
Offline necromonger
Re: 750 dbl pumper
« Reply #17 on: January 15, 2012, 08:53:02 am »
I don't know your engine specs but a 570 cm to 600 cfm should be all you need.
new build,1978 chevy 3/4 ton 2 wheel drive 350 4 speed trans.
Re: 750 dbl pumper
« Reply #18 on: January 15, 2012, 12:02:50 pm »
*87-95 rollerblock 2 bolt main (studded mains )
*cam (roller) 268 @.490 lift
*procomp 1.5 roller rockers nonself align
*vortec EQ heads ,screw in studs withguide plates
*comp cams 7.2 push rods(5/16)hardened
* rpm air gap dual plane hi rise intake
*melling hv55 oil pump and pick up
*7 quart oil pan
*KB silverlite dished pistons .030
*procomp 5.7  rods with arp bolts
*3.75 eagle cast steel crank( 103523750)
*400 pioneer flexplate (fra-159)
*summit 400 balancer with removerable weight
*clevite rod and main bearings
*hasting rings
*liberty true dbl roller  timing set
*pro comp hei distri
*procomp hi torque  mini starter 3hp
*procomp 155gpm electric fuel pump and regulator
*350th trans b&m shift kit with 3.42 or 3.73 gears
* dual 40's  flowmaster 2.25 exhaust with x pipe with summit long tube headers
*650cfm holley(80783c) or 750 cfm dual feed(80508-1) or 670 cfm (80670)or 570 cfm (80570) all four of these carbs are dual feed (they ARE NOT double pumpers )
*spectre dual carb hat (custom cold air ducts )
* extra goodies  chrome alt and brackets,power steering pump and aluminum pulleys
*other mods later are dual electric fans
*.this is my 383 build .i hope to be around 400 torque 380hp atleast
« Last Edit: January 15, 2012, 01:41:55 pm by 305chevy c-10 »
18T5C10
Re: 750 dbl pumper
« Reply #19 on: January 15, 2012, 12:45:21 pm »
Here's one more viewpoint.
Referring to your list, your significant power adders are:
* displacement
* compression
* camshaft
* heads
* intake
* carb
Your list doesn't mention exhaust, trans or gears.
650 will make a respectable daily driver in the RPM range will use the most while providing reasonable economy if you don't hammer the accelerator.  670 will slightly soften the lower RPM response, but extend the mid-range a few hundred RPM, with a gentle trade-off in economy.  I think 750 is too much air for your build and will probably leave you regretting it in the long run.
Re: 750 dbl pumper
« Reply #20 on: January 15, 2012, 01:46:52 pm »
with 32" rear tire 30" front
18T5C10
Offline necromonger
Re: 750 dbl pumper
« Reply #21 on: January 18, 2012, 09:52:13 am »
OK 600 or a 650 will work 600 better mileage 650 better performance.
Offline onelow84
Re: 750 dbl pumper
« Reply #22 on: January 18, 2012, 03:55:04 pm »
UH OH I have a 4.3 with a 750 dp blow through carb on it, I guess I better take it off. maybe it will go faster than 10.20's in the 1/4 then lol
« Last Edit: January 18, 2012, 03:59:39 pm by onelow84 »
Re: 750 dbl pumper
« Reply #23 on: January 20, 2012, 06:31:33 am »
     That statement is pretty bold with no facts to back it up.  :-[
Offline 1980c10
Re: 750 dbl pumper
« Reply #24 on: January 20, 2012, 05:44:51 pm »
I have very similar specs on my 350 w/o a stroker kit.
it is a '75 block
-vortech heads, edelbrock performer intake
-similar cam to yours
-flat top pistons
-headers, dist, e-fan, exhaust, 5 speed etc.
I have run both the 770sa and the 670sa on the dyno
The 770 ran great out of the box, the 670 needed bigger jets to keep up with the numbers the 770 could do.
I went with the 670sa with bigger jets to keep the vacuum up for better street manners and throttle response.
end results were 393 hp and 432 tq.
I would expect a little more with your engine.
sounds like a very solid set up but don't go too small on the carb, I don't think a 500 could keep up and would be hesitant of a 600.
btw I get 17-21 mpg
Re: 750 dbl pumper
« Reply #25 on: January 20, 2012, 08:59:17 pm »
wow  :o i like those numbers if my torque and hp hits that range .i will be pleased money well spent .
18T5C10
Offline 1980c10
Re: 750 dbl pumper
« Reply #26 on: January 21, 2012, 03:59:19 pm »
You should do better, one nice improvement (if you haven't asssembeled it yet)with your combo would be flat top pistons; this would keep you under a 10:1 CR and can still run 87 octane. That is how mine is set up but it does make a big difference with 92 octane.
I guesstimate my cr to be about 9.7:1
On a side note; I also run an open spacer between the carb and intake-this keeps the a/f ratio even from bank to bank.
I do have my vacuum advance hooked up and run 31 degrees advanced.
Jet sizes are F:68 R:72. I kept them a little smaller on the primaries for mpg reasons if I take it easy.
Also consider a dyno tune; mine cost $250 but netted another 20 hp. and your engine will be test run and broke in before you go through the trouble of installing it. Oh and its great to see the numbers. Most likely you'll make some of that money back on mpg savings. Then of course post your results here for all to see.
