Author Topic: Rear Disc Brake Conversion  (Read 47297 times)
Offline TorchRed77Vette
Re: Rear Disc Brake Conversion
« Reply #15 on: August 16, 2011, 12:45:51 pm »
So for the people who have done the rear disc swap, were you able to use the original front disc/rear drum master cylinder, or did you swap to a front disc/rear disc master.  If so, where did you get it from?  I know my '77 Vette has four wheel disc, do you think a replacement master for it would work on the truck (that is if a swap is necessary)?
1978 C10 Fleetside Short bed.  383 Stroker.
  ___________
 /''T''|[___|___]__
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
