Author Topic: 4wd rear cab mount Updated w/pics  (Read 13907 times)
Offline jdl71
Re: 4wd rear cab mount Updated w/pics
« Reply #15 on: May 30, 2011, 07:47:44 am »
Is the last picture you posted 2 pieces or is that just one piece?
2 pieces above and below.
Offline jdl71
« Reply #16 on: May 30, 2011, 07:51:41 am »
What I'm making of this is that the aftermarket replacement items are different then the originals. If the spacing is correct from the frame up in all 6 areas then the shape & number of lumps (assuming it can carry the weight), length of the bottom area & bolt length aren't relevent.
I believe that is what you have going on, I would like Chris to verify that this is the case & not the wrong parts for your application. Lorne
I've came to the same conclusion. It appears the replacement mount will put the cab back in the proper position so I'm just going to put in on. The front mounts were different also, but did come up with the correct amount of spacing once I figured out the order of assembly. Thanks to you and the others for your help. I didn't realize this would be so difficult to figure out. I figured just about everyone has done this and someone would have an answer for me fairly quickly. Guess it's not as common as I thought.
Offline HAULIN IT
« Reply #17 on: May 30, 2011, 09:31:23 pm »
I think there is a slight difference in the 2x4 vs 4x4 in height due to the T-Case clearance.
Nah, that isn't the case. Think about it...the cab front uppers & rad support uppers are the same 2wd & 4x4, the beds are all the same sitting on the frame, the cab bottom where the mounts go are all the same & the bodylines all line up.
What is different is where the crossmember is in the frame rails. In the 4x4's it's lower to make room for the taller bushings that sag more ???  I checked this out a while back...A friend had bought a nice 2wd 3/4 ton truck & I had a complete but kinda - no, correction  ;) a really rusty frame (trans, T-case & shafts) we were going to put the front 4x4 brackets on the nice frame & a 2" block in the rear. Part of my figuring was: "Why are these bushings different?" The outcome, it must have been to try to eliminate vibration under the people in the seat from the transfer case...it serves no other purpose. If the crossmember was moved up on a 4x4 frame to the placement of the 2wd crossmember, one could buy a 2wd bushing kit &  everything would be the same & it wouldn't sag in a years time. Or in the case of what we were planning: Do nothing to the crossmember & use all of the 2wd bushings.
He sold the truck & we never did the swap...the guy that bought it did the conventional frame swap, however he threw away a MUCH better frame than he used...which was the basis of my/our thinking. Lorne
Offline jdl71
« Reply #18 on: June 05, 2011, 07:46:15 pm »
I got the back mount in today and it fit just fine. Doesn't look anything like what came out, but spaced the cab properly so the body line on the cab is no longer and inch and a half below the bed body line.  ;D
