Author Topic: supposed to go out tonight and now this...need help  (Read 11390 times)
Offline 1980c10
Re: supposed to go out tonight and now this...need help
« Reply #15 on: May 28, 2011, 08:32:25 am »
might be a good time to rebuild your carb.
« Reply #16 on: May 28, 2011, 12:27:03 pm »
ok got the truck home, it seems to work out but definetly have a problem with the carb. I am ideling at 1300 rpm and when i tun the truck off it tries to stay running. All of this just seem to happen today up till today everything worked great. any ideas on what I should do now?
Sounds like your timing is off if it runs when key is off. Or just shut it off in gear...
Offline Buddy
« Reply #17 on: May 28, 2011, 12:39:42 pm »
Ok took it all apart this afternoon. Blow the carb with some compressed air. Did a few other things. Notice the line going to my brake booster was kinked. Replaced filter as well. Put in all together again, seems to be working ok now idle is back down to 800. Will run it tonight and see what happens. Thanks again guys.
Offline slammed79
  • Thou shalt not drive stock
« Reply #18 on: May 28, 2011, 10:31:03 pm »
I think he just had it rebuilt. I'd definetly check the timing again, and make sure your fuel line is not too close to the headers.
Praise the lowered
