Author Topic: 87 hydraulic clutch  (Read 30314 times)
Offline 1980 gold
Re: 87 hydraulic clutch
« Reply #15 on: July 04, 2011, 09:47:07 pm »
wow thanks a lot!!!!! you did a lot of work on a holiday. i appreciate it very cool
Offline 1980 gold
« Reply #16 on: July 04, 2011, 09:53:20 pm »
its funny i also just ordered a 5/8" master for a toyota as plan b with a bigger reservoir just in case i like that idea better than changing the slave too but again i appreciate all the work on the 4th of july.
Offline 1980 gold
« Reply #17 on: July 17, 2011, 08:34:30 pm »
so i went to try my bigger slave cylinder and i went to stop by the auto parts store to grab a couple of what i thought were male flare fittings and parts guy much smarter than me looks at the slave i had and said this is not a threaded fitting its a pressed in plastic fitting ( its pressed in and then a pin gets pushed in next to it to secure it) which is all well and good except what kind of fitting is that and where do i get one and can it go on a steel brake line?
Offline 1980c10
« Reply #18 on: July 17, 2011, 11:03:20 pm »
I had a similar situation as to what you have now as my slave cylinder is from a '98 chev p/u. I went to the junk yard to get the end of the line and fitting cut it off 8" or so and flared the end to attach it to a brake line. Also the pin I needed ended up being a pretty common roll pin. The line pushes in and is then secured with the roll pin. I can actually rotate mine when it is installed but it doesn't leak at all.
Offline 1980 gold
« Reply #19 on: July 18, 2011, 12:01:46 pm »
was your slave plastic? it sounds similar and the end is metal and can be put on regular brake line if you flare it? thanks for responding
Offline 1980c10
« Reply #20 on: July 18, 2011, 10:11:48 pm »
My slave is metal and some of the factory line was plastic but I was able to cut it near the slave where the line was metal then flared an end on the line where I could connect it to a brake line which leads to my clutch cylinder which happens to have a fitting that matches a brake line end.
Offline 1980 gold
« Reply #21 on: July 19, 2011, 09:09:37 am »
thanks sounds like a good idea
Offline Edahall
« Reply #22 on: July 19, 2011, 10:23:42 am »
I did some checking for you and the stock slave cylinder for your truck is a 13/16".  I'm not sure that going to a 1-1/4" slave cylinder is going to work.  I'm afraid the volume would be too large for a any master cylinder less than 1".  A 5/8" master cylinder would not push that slave cylinder far enough to disengage the clutch.  On the other hand, a slave cylinder on the order of 7/8" or possibly 1" might work.
1990 ¾ ton 4x4 Chevy Suburban
-Gear Vendors Overdrive
-Upgraded Holset HX-35 turbo
-NP205 iron transfer case
-3.73 gears
-2" Lift
Offline 1980 gold
« Reply #23 on: July 19, 2011, 10:29:41 pm »
i went to try this sunday ( the slave ) and i had to laugh i went to buy a fitting for it turns out its not a regular flare fitting so  i basically canceled that plan  until i either find a fitting that will work may on the other hand order a 1 inch slave it looks like most of them will bolt up the same and have the same dimensions
Offline 1980c10
« Reply #24 on: July 19, 2011, 10:52:47 pm »
Like I mentioned I got my fitting from the local u-pull-it yard as i couldn't buy one from any local places without buying the whole line.
