Author Topic: very high idle. fouled plugs. idle mixture screws not responding.  (Read 27305 times)
Re: very high idle. fouled plugs. idle mixture screws not responding.
« Reply #30 on: August 07, 2011, 04:18:28 pm »
the real thing to worry about is if it stalls and you dont want it to be to lean
Offline txchainsawgogi
« Reply #31 on: August 09, 2011, 11:37:31 am »
After it warms up...it starts idling high AGAIN. It was low two days ago...but when it gets hot...boom 700rpm/1300rpm (drive/park).
Also it dieseled yesterday like its rich but the exhaust is the cleanest looking I've ever seen it.
« Reply #32 on: August 09, 2011, 12:46:31 pm »
dieseling=timing usually.
Offline 1979C20
  • Kyle Taulton.
« Reply #33 on: August 09, 2011, 12:56:53 pm »
X2
Advanced too far.
« Reply #34 on: August 09, 2011, 07:14:39 pm »
oh yeah...got it. This high idle thing has me stumped AND p.o. big time.
« Reply #35 on: August 17, 2011, 11:12:11 pm »
new symptom! its no longer carbon fouling the plugs, now the plugs are showing signs of the mixture being too lean. the idle is (usually) within the ballpark range of where it should be but its a very rough, sluggish idle.
if youre sitting at a stop light it'll noticeably shake and shimmy while the rpms dip around the 550 mark. idle in park is fine. driving conditions are fine.
the other odd thing i noticed is a slight bit of grey smoke on start up that doesnt happen everytime, and is so light that its hard to pinpoint where its coming from. looks like its coming from the under the front of the engine, possibly by the harmonic balancer.
Offline 1979C20
  • Kyle Taulton.
« Reply #36 on: August 18, 2011, 02:45:20 am »
Check the plugs from both sides of the motor, if they are both lean burning, screw each mixture screw in 1/4 turn. Then check pkugs again.
« Reply #37 on: August 18, 2011, 05:06:46 pm »
 I thought turning it in made it leaner?
Offline 1979C20
  • Kyle Taulton.
« Reply #38 on: August 18, 2011, 06:33:05 pm »
Turn the screws in, gives less air, makes it richer. Turn screws out gives more air, makes it leaner.
« Reply #39 on: August 18, 2011, 07:59:26 pm »
http://www.ehow.com/how_7763497_tune-quadrajet.html
love step number 5 but you need to start from scratch
« Reply #40 on: August 20, 2011, 12:32:21 pm »
when that person says "plug the tach into the vacuum port on the carb" do they mean a vacuum gauge?
« Reply #41 on: August 20, 2011, 08:47:23 pm »
I hope so lol
