Author Topic: Weird Transmisison Noise  (Read 9503 times)
Offline 1979C20
  • Kyle Taulton.
Re: Weird Transmisison Noise
« Reply #15 on: December 23, 2011, 12:28:16 am »
Have you ran the truck with the inspection plate removed? The inspection plat on my truck got bent at the top and rubbed against my fly wheel. Made kind of a similar sound.
« Reply #16 on: December 24, 2011, 12:38:05 am »
Im going to say he didnt have an inspection plate on because he unbolted the torque converter.
Offline biscuit41
« Reply #17 on: December 26, 2011, 10:42:10 am »
I pulled the tranny and took off the flexplate. It isn't cracked. If it is warped could it make this noise?The engine is a new GM 350. I hope the bearing isn't spun. I primed it before the first start.  That would really suck.
1985 C10 Longbed
Offline biscuit41
« Reply #18 on: December 26, 2011, 06:13:08 pm »
I feel like an idiot. After dropping the trans and checking the flexplate I put it back on started it up. After cursing for an hour and downing a few beers I decided to remove the starter. The noise went away.  Sucks that I have to put the trans back on but at least it should be a cheap fix.
Thanks guys!
1985 C10 Longbed
