Author Topic: steering shaft loose by firewall  (Read 14781 times)
Re: steering shaft loose by firewall
« Reply #15 on: September 30, 2011, 05:14:32 pm »
Even if you use advanced search just “check all”
Offline Engineer
« Reply #16 on: October 05, 2011, 10:43:09 pm »
There is nothing wrong with your column.....or the bearing.
What has happened is the ball bearing has worked it's way out of the plastic holder on the firewall end if the steering column tube. There is a plastic bearing retainer that the ball bearing is pressed into. The big snap ring around the metal collar on the end of the column holds all of thus in the column tube.
You should be able to just simply drive the ball bearing back into the plastic retainer and this should fix your problem. That is assuming the plastic retainer isn't broke.
1997 Chevy Blazer 4x4
1979 Chevy K-30 4x4 4sp 4.10
