Author Topic: 1990 Blazer  (Read 19852 times)
Offline Big Katz
Re: 1990 Blazer
« Reply #15 on: September 28, 2011, 10:00:05 am »
I like it! I have been looking at a soft top for the same reasons as you. Is completely removing it similar to removing the hard top. I ask because I will still want to run my hard top in the winter.
Offline crewcabfred
Re: 1990 Blazer
« Reply #16 on: September 28, 2011, 01:10:10 pm »
Well for the most part yes.   You just remove the canves then unbolt the frame.
The only thing im not sure about is the seals.    The soft top frame can be installed without removing the inner hardtop seal that is glued to the blazer itself rifht below the cab bolts.  So that would work just fine.
However the soft top requires you to install a seal on the cab right above the cab bolts.    It is installed right where the outter hardtop seal sits.    But looking at it, since the outter seal stays on the hard top when removed, you could probably remove the outer seal from the hard top and i bet the soft top seal would work in its place.    The soft top seal sits in the same place and is close to the hardtop seal in size, only differnce is that it is attached to the truck instead of the top.   Hope that helps i know its confusing.
Offline Big Katz
Re: 1990 Blazer
« Reply #17 on: September 28, 2011, 03:20:56 pm »
It makes sense. Thanks for the info. Now I just need to get my wife to let me buy it...
