Author Topic: Removing balljoints on a 10-bolt...  (Read 18745 times)
Offline DustyRusty
Re: Removing balljoints on a 10-bolt...
« Reply #15 on: November 10, 2011, 07:35:30 pm »
NAPA has the ball joint spanner wrench in two brands.  Here are part nos:
1.  BK7002467.  (Balkamp) Cost is ~ $21.50
2.  NCP 2782030.  (NAPA Chassis Parts) Cost is ~ $29
Rusty
Customized by rust.
Offline 81GMCBILL
« Reply #16 on: November 10, 2011, 09:21:58 pm »
I doing mine too, the upper ball joint comes with the sleeve attached to it.
Q-  the "spanner socket " you mention, is this the socket that backs the adjusting sleeve out?
      the sleeve on top has four notches (like the axle nut) but is way smaller. Does Oreilly have this
      socket ?
thanks..
85 GMC K25 4X4 383/th400/np208
Offline Sodium Duck
« Reply #17 on: November 11, 2011, 03:49:16 pm »
The small, four notched sleeve you're talking about is what the spanner socket is for.
1985 K10, corporate 10-Bolts front and rear, 6" lift, 35's, 305, auto, longbed.
