Author Topic: Installing Cab Roof Clearance Lights  (Read 28777 times)
Offline Jason S
Re: Installing Cab Roof Clearance Lights
« Reply #15 on: October 22, 2011, 11:45:30 pm »
If you're trying to go with the stock look, take a close look at the photograph and note that the outside clearance lamps angle out (i.e., not set straight with the cab).
Your local auto salvage may have a truck with the correct GM lamps and wiring for less money than the replacement-style clearance lamps. You could also make templates off the cab to verify hole location...
Offline LTZ C20
« Reply #16 on: November 09, 2011, 06:31:20 pm »
Would anyone happen to know the diameter of the base of the stock cab roof lights like in the above dually picture?
LTZ Cheyenne C20
Offline Jason S
« Reply #17 on: November 13, 2011, 03:51:35 pm »
The total outside diameter of the rubber base is nearly 3 1/2 inches
The socket is approximately 3/4 inches
The lens diameter is approximately 3 1/4 inches (across mounting location on bottom)
Offline LTZ C20
« Reply #18 on: November 17, 2011, 12:46:35 am »
Thanks Jason, that is very helpful information! That helps a lot. I'll let you guys know when their on. :)
LTZ Cheyenne C20
