Author Topic: Small Block 400 Overheating in 4wd  (Read 14670 times)
Offline muddpuppy01
Re: Small Block 400 Overheating in 4wd
« Reply #15 on: January 12, 2012, 07:37:56 pm »
does it overheat just sitting still. you said it be bored out wonder if the heads have the steam port in them. Does it take awhile to warm up first thing.
Offline johnhood
  • Rough Country Suspension
« Reply #16 on: January 12, 2012, 10:00:05 pm »
sometimes it takes a while and sometimes it warms up pretty quick dependeing on the temp
1985 Chevrolet Custom Deluxe 400 Small Block TH400/NP208  6inch Rough Country Lift
Offline muddpuppy01
« Reply #17 on: January 15, 2012, 06:42:51 pm »
is the thermostat install with proper rating and working properly
running without a tstat will cause heating issues
Offline johnhood
« Reply #18 on: January 15, 2012, 10:01:20 pm »
Im Gonna review everything ive been told on here and see what it comes out to be i appreciate all yall help
yes there is a new thermostat in the truck
« Reply #19 on: January 17, 2012, 05:19:44 am »
i think the problem isnt the transfercase but just like you said before the engine works harder in 4x4 , then on top of that the engine is bored out so that would be a variable. i would lean more just to the radiator isnt big enough to cool the fluid since its getting hotter than normal due to the bored out engine
« Reply #20 on: January 17, 2012, 04:26:49 pm »
Did your truck originally come with the 400? Radiators are different sizes depending on what engine originally came with it.
Offline johnhood
« Reply #21 on: January 18, 2012, 11:19:15 pm »
My Truck Came With A 5.0 in it but the radiator has been replaced to a thicker core at least thats what i was told
« Reply #22 on: January 19, 2012, 12:18:47 am »
How many rows does it have?
Offline johnhood
« Reply #23 on: January 20, 2012, 09:22:23 pm »
the core is about 1 1/2
Offline johnhood
« Reply #24 on: January 30, 2012, 12:39:15 am »
i appreciate everyones help i found the problem it wasmy water pump was weak and slowley going out it started to overheat in 2wd also so i really started tearin it down and it turned out to be the pump Thanks Again
« Reply #25 on: January 31, 2012, 10:38:28 am »
so you fixed it ?
