Author Topic: Electric Choke not Working  (Read 43074 times)
Offline LTZ C20
Re: Electric Choke not Working
« Reply #15 on: January 25, 2012, 11:26:53 pm »
Thanks. I called Edelbrock and found the sizes for my specific carb. Primaries are .098 and secondaries are .095. :) Seems to be running much better now.
LTZ Cheyenne C20
« Reply #16 on: January 26, 2012, 07:36:19 am »
     Glad to hear you got it fixed.
Offline LTZ C20
« Reply #17 on: January 26, 2012, 07:56:41 pm »
Thanks. Running really good.
LTZ Cheyenne C20
Offline Dr_Snooz
« Reply #18 on: January 28, 2012, 12:34:17 am »
I recommend sitting down with the booklet that came with your carb (assuming you bought it new). It should tell you all the various adjustments you can make and how to get them dialed in. The carb is highly adjustable and if you take the time to get everything right, it should run pretty well. I also had a problem with the fast-idle screw hanging up on the throttle linkage making the truck run insanely rich. The stink was constant and unrelenting. I just backed off the screw slightly and it works great now. I spent a lot of time playing with jets. I would swap them, drive, smell the exhaust, drive some more, swap again and repeat. I'm pretty happy with the primaries, though I should probably go a little richer with the secondaries. As long as your choke starts the truck and opens fully when warm, I wouldn't worry about it. I just hooked the choke to the old choke wire. That may not be right, but it seems to work well enough.
Offline LTZ C20
« Reply #19 on: January 28, 2012, 02:23:32 pm »
Thanks for that. I got it running really smooth now except it wouldn't idle well, found out my coil was going bad so I have a new coil and all is better. :)
LTZ Cheyenne C20
