Author Topic: Any advice on first fiberglass project?  (Read 27504 times)
Offline klaussk
Re: Any advice on first fiberglass project?
« Reply #15 on: January 26, 2012, 05:12:13 pm »
if the ply wood you used was more than 3/8 of a inch thick then you probly could have done those edges out of wood. But i can see why you would use this for practice.At my last job I did alot of work with carbon fiber. Its like the same epoxy for both. The biggest thing for a mirror finish is having no contaminants like saw dust get into the epoxy. you can do alot with any kind of cloth and epoxy. Its actually very forging.Because its not hard to fix mistakes. Try experiments with for radical curves and shapes.
Go ahead hit it with a hammer. Theres only one level of broke.
« Reply #16 on: February 08, 2012, 10:40:55 pm »
There is epoxy based resins, and polyester based resins.
Epoxy resin although a little harder to work with as far mixing, you have to be a little more precise on the amounts. It does give you a little longer work time. It is more stable when dry, it is also more waterproof, and bonds to itself both cured, and uncured better than polyester based resin. Epoxy resin is a fair amount more expensive too.
Only some of the epoxy resins leave a wax type emulsion after they dry. If you happen to use one that does it washes right off with vinegar, and wipe clean with water. Then you can sand it without clogging sand paper.
Another popular misconception is the more resin you use the stronger. The strength is in the glass. All the resin for is to make it hold together, hold a shape, and give it a structure. When fiber glassing if you are going to cover a form be it a permanent form such as wood, or foam which is a great way to make a shape, then remove it later leaving the glass in that shape. You should brush a thin to medium coat depending on the weight of mat, or cloth you are using onto the forms surface. Then lay the glass on to the wet form dry. Use a short bristled paint brush, or a fiber glass roller to force the resin up through the glass. Working any air bubbles out in doing so.  You should only be able to saturate the glass with the resin no more. Sometimes you need to add a little here or there. or mop some up with the brush.
Once your first layer has dried, if its not completely cured with epoxy resins you can do one, two, or more layers over it in the same fashion.
When using polyester based resin you will need to let it dry enough to give it a half way decent sanding to create a mechanical bond for the next layers.
You shouldn't brush on polyester based resins as top coats. They can shrink later on as cause blemishes. or have air bubbles that lead to pin holes when you sand them.
As far as epoxy based resins they make fillers you can mix with them to make them more like a body filler. Fine sawdust works for this as well. Like the type you would get from a belt, or palm sander dust bag.
Once the glass is done you should only need filler to hide the rough surface of the glass. Or to blend it in with old glass if its a repair.
As far as working with wood. You should be able to shape the edges and corners or the wood any way you want. If its plywood, and leaves craters because of the layers use body filler to fill in holes, etc.
Offline TimberwolfFXDL
« Reply #17 on: May 05, 2012, 09:43:18 am »
I've read about using builder's foam insulation board as a buck for fiberglass.  Anyone done it?  The article I read (many years ago) was based on building a gas tank for a motorcycle, but the process seemed like it would work for just about anything.
They laminated pieces of the pink foam board together using a low VOC adhesive that wouldn't melt it.  Then they carved what they wanted, coated it with fiberglass, and when done, melted the foam with acetone and poured it out as a liquid.
Offline SUX2BU99
« Reply #18 on: May 12, 2012, 02:04:25 am »
Floral foam (green stuff) is better to shape with, as it doesn't get eaten by polyester resin.
What the OP could have also done is make a frame for that console out of wood and then stretch fabric over it for the shape. That's an easy way to get curves and non-flat shapes. This is done very commonly in the car audio world. Using a material like fleece allows for a lot of resin to get soaked into the fleece which makes it stronger once cured. After that, apply fiberglas mat to the BACK side of the fleece. Lots of guys put it on the front and you make a heck of lot more sanding for yourself.
